I just finished messing around with my friends copy of Final Cut Studio 2 and it is definitely worth it for us HV20 owners. No more of the AIC, cut the first few frames trick as previously outlined in the forums. With ProRes and Compressor 3 the process has been simplified. Just send the clip to Compressor, choose the ProRes 422 24p and then choose reverse telecine From the de-interlace dropdown menu located in the frame controls tab of the inspector. If you want you can also change the size and pixel aspect ratio in geometry. It looked great outputted as a 1920 x 1080 square pixel movie.
i tested this by intentionally starting on the wrong frame for the cadence and compressor didnt care at all. One less step for real 24p.:thumbup:
I did not have time to test this with a long clip that has a start stop break in the middle, but i will repost later after i had a chance to.
