Whether you’re shooting a commercial where exquisite color rendition and high contrast is important, or a tense, dramatic sequence in low light situations for a feature film, Compact Prime CP.2 Super Speed lenses offer you the performance you need to get the scene right. They are an ideal complement to the existing range of CP.2 lenses. The Compact Prime Super Speed lenses show less aberration which results in an overall better image quality. Images appear much sharper and show a much higher contrast. The CP.2 Super Speed lenses cover a full-frame sensor format and are equipped with the interchangeable lens mount system for use with a variety of cameras ranging from HDSLR to professional cinema cameras.
Application
The aperture of T1.5 gives you an even wider range of creative possibilities when shooting in low light environments or when aiming to achieve a cinematic shallow depth of field. Giving you the freedom to experiment and the flexibility to make your vision become reality.
I think this year with the $4000 I have I am getting this lens Compact Prime CP.2 Super Speed 35mm 1.5 Apeture. I think I might be crazy.
- T1.5 for use in low-light situations and for cinematic depth of field
- Interchangeable mount
- Full-frame coverage
- Standard focus and iris gear positions
- Compact size and low weight of 0.9 to 1.1 kg
- Robust cine-style housing with the ability to utilize a follow-focus system
Application
