GH3 Color grading GH3 footage...
Kindredmachine
I'm not a good color grader but I primarily use Colorist II + Looks in Premier CS6 for all of our work. I was curious though, when shooting between the 50 IPB vs the 72 All-I on the GH3, does one hold up to grading better then the other? They're two different styles of compression but I hoping they were virtually the same in post so I could shoot via 50mb/s mode to get a cleaner initial shot without having to use a denoiser.
Thank you very much!!
Thank you for the reply and resulting from my own testing the 50mb displays less noise than the 72 All-I but my question was regarding what holds up better in post. "Initially", as in, before grading, the IBP is better but you can always denoise in post and if you could push the image more utilizing the All-I mode, then it may not be worth shooting in IBP...
So... does anyone know if there is any difference in how each holds up in post?
