Avid's decoder is avb in MetaFuze and it's free;Aside from Avid products which i don't use, is there a recommend reference for DNxHD injest. I'm on Win 64, the DNxHD are wrapped in QuickTimes and i'm using Nuke X and the adobe suite. I believe NukeX defers to the standard QT wrapper - but i don't know for sure. Is it worth transcoding from the QuickTimes and rewrapping the data in a different wrapper? What choices do i have for performing the transcode process?
http://www.avid.com/US/industries/workflow/MetaFuze
In additional to Dermots perfect example of why a recorder is vital in some post cases, if you have detailed scenes and any movement the built in AVCHD can fall apart very quickly, so whilst you may pull a secondary on a static scene, when that scene or camera moves you may suddenly loose your key because of the compression blocking.
For the price of a BMD there's simply no reason to not go down this route. And i don't have any shares in BMD.
+1 I also don't own shares.. but is was a no brainer for my workflow and projects
