Robert_Niemann
Will there be an anamorphotic adapter for the HVX200 to shoot in 1:2,35?
Robert_Niemann said:Will there be an anamorphotic adapter for the HVX200 to shoot in 1:2,35?
jrv3034 said:I hope the HVX includes a setting for 2.35:1 cinemascope framing guides in the LCD. That would make framing shots a heck of a lot easier! I know when I shoot something in 1080/24p, it's going to be cropped to cinemascope. I can't wait!
http://www.aspectcorrect.comseejay1031 said:Even if the HVX doesn't include 2.35 guidlines, I'm sure that someone will release an lcd protector film with guidlines printed on.
Bummer. It seems like such an easy thing to implement... Obviously they can't add it now, since I'm sure all software and programming is set in stone for a December release. Hmmm, maybe for the HVX200a.khmuse said:Regarding the in camera "guidelines" I asked this question of Jan at Resfest in LA and she stated that the answer was 'no, not even the Varicam has that feature'.
Simon Wyndham said:Actually optically stretching the image vertically and then projecting anamorphically at 2.35:1 is a good way of doing things to make maximum use of the resolution.
Canon sells a device for doing just this very thing for use on cameras like the Varicam although it is quite a bit of extra length to the camera.
http://opd.usa.canon.com/html/industrial_bctv/p_hdec_ACV-235_intro.shtml
Why? Can you be more specific? 'cause, as I can see, we have in the some wave...and both experiences can be useful.khmuse said:A little over a year ago, we started work on a feature film project that was intended to be film out and shot with a DVX/LA7200 combination. We shot 8 days (a little over 20 minutes of the film) as a feature development project, then spent the money to blow it up to film for an investors screening. The outcome was reasonably acceptable, but in the end, not good enough to go forward with the project so we abandoned the concept of this camera/adapter combination for a theatrical project.
khmuse said:I would be very interested to learn how anyone else intends to approach a scope aspect ratio project with the HVX.
Who knows? (DVX did it for a non-cinemascope print). And that's why we are looking for a solution without resolution losses. I'm convinced after HVX release, there will be a similar solution that ones for 16:9 DVX but now to 2.35:1 without crop (like ACV-235 but there's other business - it's only a question of numbers/market/profits/money), or will I be (only) a believer?KCFilms said:I was originally considering a cropped 'scope' solution using the HVX for a feature I'm working on. I decided to abandon that idea, beacuse I wanted to use the overcrank capabilities in 720P while maintaining as much resolution as possible for a possible film blow-up.
I just can't see this camera carrying enough resolution (cropped and blown up) to make a satisfactory cinemascope print. But, then again, I may be wrong.
Emanuel said:Why? You can be more specific? 'cause, as I can see, we have in the some wave...and both experiences can be useful.
So much?... And a step ring possibility to 72mm for the DVX adapters. How will it be the result? Isn't it possible without losses or vignetting or other freak issues?KCFilms said:I remember talking with a fellow from Century Optics about a 16x9 adapter for a lens I have with an 82mm filter front (same as HVX.) The guy said producing an anamorphic adapter that size would be very difficult (read, expensive.)
Add to that diffuculty, the need to maintain high resolution for the HVX and I think we're going to at least match the cost of the camera.
What's exactly your opinion about that you saw?...(I'm in Europe!) Did you like as your expectative or not? I know that there isn't progressive, blá blá blá blá blá blá...60i but maybe it's not possible yet to know its cinematic/film look properties or think in a possible comparative with F900 footage, or I'm wrong?khmuse said:I have high aspirations for this camera, with its 4:2:2 color sampling and apparently very high resolution (from what I saw at Resfest in LA) it may be just what we need.
Indeed...khmuse said:Waiting with fingers crossed!
