C200: Cinema RAW files not recognized in DaVinci Resolve 14
spinkscapes
So I'm trying to edit the CRM files from the CFast 2.0 card in Resolve, however, Resolve refuses to display the CRM files in the media window and any attempt at importing the file in any other ordinary manner does not work. Currently I do not think my version (14.0.0b.020 of the Public Beta) of Resolve natively supports Cinema RAW.
Any assistance on how I can import these files would be greatly appreciated.
Transfer the files (leave card structure intact) onto a harddrive and try again (unless you have but it sounds like you're keeping them on the card).
Yep, the file is now in My Documents but Resolve still does not recognize it.
When I use File - Import Media it can see the CRM file but when I press "Open" there is no file imported into the project.
Did you copy everything from the card as is meaning not just the CRM files? Not sure what the C200 card structure looks like, but you might need to drag and drop everything from the card (if applicable) exactly how it is including all of the folders/sub-folders (like with AVCHD, etc).
Also, if you still have the card, try importing straight from there into Resolve.
Haven't kept up with Resolve's updates so it could just be the version as you mentioned.
All fixed. Just needed to update to the newest version of Resolve (which I thought I had downloaded, but apparently not).
