My next video will be a deeper dive into the color modes, sharpness, and noise reduction settings. I am coming up with a way to scientifically measure those modes now.
I really appreciate all your work. Thanks!
Tim
I'm on the fence about -1 vs -2 for cc in post, but I use -1 unless noise is intrusive, so for me the settings relate to light, ISO and the presence of flat backgrounds which emphasize noise. Contrast has to come down at least to -1 for some noise reduction, but of course contrast relates a bit to the lens as well. With the Olly 45mm I have no hesitation in lowering the contrast slightly, other lenses don't yield the same terrific contrast across the frame at lower F stops. In any case, -1/ -1 is an OK place to start, new ppl to the cam have to start somewhere and many ppl will start with a kit lens that is slightly less sharp and contrasty. I'm hoping Panasonic will address the NR issue in the next firmware.
Contrast is easy to add but difficult or impossible to remove. So always set contrast to minimum on the GH2
This is true in theory, but on the GH2 the contrast control works in a particular way. Now, obviously, by altering contrast you get no more bits to play with - you are still limited to 8 bit samples; the contrast can only affect how these are allocated. To me, I feel as if I want to get it as close as possible in-camera so that as few of these 'bins' as possible are wasted. In the GH2, I believe that when you adjust the contrast curve, the overall dynamic range isn't really altered much at all, leaving the blackest and whitest points at around the same values, and it only alters the curve in the middle. When you lower the contrast, it boosts shadows and flattens the mid tones, allowing for a flatter curve in the mid tones and highlights. As a side effect, the shadows are raised (stretched, rather than flattened) which brings out more detail (which may be noise) in the shadows.
This may be desirable if you were going to boost shadows and flatten highlights like this in post anyway, since now you won't have to manipulate as much and you'll get less banding. But if you then want to go back to a more contrasty or less "flat" look in post, you'll need to crush that extra detail in the shadows out again, which will have some small impact upon your image quality. Some of the extra bandwidth set aside for these elevated shadows will have been allocated in vain, and you will potentially increase banding in midtones by stretching them out.
I'm not saying there is one contrast setting that all people should use - I believe you should probably consider what look you want to get in the final product rather than going for a one size fits all approach. If you're interested, I personally am using Contrast "0" a lot of the time right now.
I am very keen to see the work mpgxsvcd mentioned he is doing, measuring the various film mode settings.
Saturation is where I don't get why people lower it. You can remove saturation easily, but adding is difficult or impossible (since it's not a RAW image file, it's a compressed H264 stream).
Saturation is a complex thing. Increasing saturation doesn't just increase chroma and mean more bits allocated to it. Saturation is about colour purity, and increasing saturation means removing complementary colours from a colour... a highly saturated yellow has no blue in it, for example. Changing saturation doesn't affect H.264 encoding in quite the same way contrast does. The biggest problem of shooting with high saturation is you can clip the colour space the camera records in. My advice? Pick your personal preference between -2 and 0 saturation, but you probably want to avoid +2.
Do you have an ETA, yet?
looking forward to it.
I am shooting the demo clips for the color mode tonight. I am aware of the yellow shift that everyone is seeing in the highlights for Cinema. I will be specifically looking at what causes that and if it can be remedied in camera.I'm looking forward to the video on film modes also! thanks
I plan on testing Cinema and Smooth for all ISOs from 160 to 12,800 for stills and 160 to 25,600 for video(Yes I believe that it actually goes that high with the shutter priority mode exposure trick). I will test those ISOs for Cinema and Smooth for hacked(176 mb/sec I frames, 42 mb/sec stock GOP, and total stock) firmware vs. new Panny firmware. I will also run through all color modes at ISO 160, 800, 1600, and 3200 for stills and video.
In addition I will test the ISO bug for changing it from a lower ISO to higher ISO vs. changing from a higher ISO to a lower ISO.
This testing is going to take a long time but I plan on doing it right. I will setup everything in a pitch black garage with a tripod and with a single bright video light to give the scene maximum dynamic range. I will make sure that the camera doesn’t move at all inbetween shots and that the video light maintains an even brightness throughout the testing. I need to get some more AAs to insure that.
I will post the review video to youtube. However, I will also put all of the original video files for any results that are questioned to Vimeo for download.
mpgxsvcd,
HUGE, HUGE Jedi points for this effort Sir!
Huge...
