cheap monitor
New_Zealand
I'm looking for a cheap monitor for the t3i. Something that I could hook up quickly to see if I have my shots in focus. It will only be used for blocking and focus.
Thanks - do you mount it onto the camera or have it mounted on the base plate? I saw two different setup on that webpage. Also what is the battery life? Thanks
You can use an articulating arm or a ball mount and mount it to the hotshoe on the camera. You could also mount it to into the slot for the spare tie-down screw, if you are using a Manfrotto Quick Release System.
