Hello,
currently I'm preparing for a trip with my C500 Mark II that will include capturing footage at night, specifically polar lights. Second camera will be a C70 with the Canon Speedbooster, both cameras will use the Sigma 14mm F1.8 (the C500 will use the cinema version of that lens).
Right now I'm trying to find the best approach on reducing noise because obviously it will be pretty dark. Apart from watching a lot of YouTube tutorials, I'm doing my own experiments as well and I ran into a pretty massive contradiction, at least from my point of view. Eventually somebody with better insights can help me?
There are a lot of claims that when shooting RAW, ISO can be changed in post and in my preferred NLE DaVinci Resolve Studio, the parameters offered for manipulating RAW are indeed allowing me to change ISO as well.
So I made a test and maxed all capabilities of the camera, e.g. using shutter of 1/12 and shot a series with alternating ISO settings. Starting from 100, I went to 800, 6400, 12800 and finally 25600, each one minute only. Both the C500 and C70 were side by side. I left internat noise deduction at default settings, although I found a tutorial that recommended changing Frame Correlation.
Once I got the clips in DaVinci, I started tweaking the footage and just like I suspected, changing the 100 or 800 ISO to 12800 was not even close to the footage shot in 12800 in-camera. There was a lot more noise, the colors were worse and observing the waveform display, it looks like changing ISO was doing nothing else than raising levels with the information still lost in noise.
So my conclusion is that changing ISO in post is not possible and proper attention still needs to be paid on exposing correctly with an appropriate ISO setting. Which is quite different from what several talking heads claim, at least the way I understood their explanations.
Am I missing something in my experiment or are those claims about being able to change ISO in post wrong?
Kind regards,
Frank
P.S. The footage captured with the C500 in ISO 12800 looked quite good, unfortunately the C70 could not quite keep up. Experiments with in camera noise reduction will follow.
Kind regards,
Frank
