Run&Gun
First let me say that the footage/data is(or appears to be) safe a working, but I haven't had or seen this problem before and I'm wondering if anyone here has or knows what happened.
I was on a three camera shoot(2x C300's & 5DMKIII) for four days. Besides shooting I was data wrangling. I was dumping the cards to client supplied drives and redundant back-ups to my NEXTO. Normally I would hook the ext drive to the NEXTO and do two simultaneous copies, but the ext drive was limited to USB 2.0 connection to the NEXTO(it didn't have an eSata connection), so after the first day I made a copies to the client drive through my RMBP and then my NEXTO. It actually ended up being MUCH faster this way.
Over the four days I copied about 23 cards. Everything was going smoothly until one of the last copies of the last day on one card. I inserted the CF card into the USB 3 reader hooked to my laptop and it almost immediately started throwing an "improperly ejected" error message. The message would disappear, then the card would disappear from the desktop. Then it would reappear and the cycle would repeat. I quickly clicked on the card and opened it up before it disappeared one time and the CONTENTS folder was not showing(nothing was). I almost felt sick, but I knew I was recording. I pulled the card, put it back into the C300 and it played fine. Tried it on my laptop again and the same error cycle happened again. Pulled the card AGAIN and re-booted my laptop. Tried it again. This time it works. I transfer the data and then open XF Utility and play the contents on the ext. drive. All good. Thank God. So I insert the card into my NEXTO for the second safety copy and it hangs. It detects the card, says it's PARSING the card(like normal), but will not get past that. I pull the card and try it several more times with the same result. I copied the remaining two cards with no problems.
So, any ideas what happened?
