Severe TM700 frustration. I used it to shoot our 4.5 hour tech rehearsal which worked great. I used 1080i mode to fit that length into the 32GB internal memory. Next day did "erase all" to clear memory, and shot another 4.5 hour rehearsal- worked great. Downloaded that night into my older PC because my new one was busy downloading from the other camera. I had not installed the Panasonic "AD Writer AE 2.1" software on the old PC, but no problem, the camera appears as a hard drive, so I just grabbed the .MTS files directly from the AVCHD/BDMV/STREAM folder- OK job done- 2 am, go to bed.
Big show night! Turn on camera, select "erase all" files, completes, says "NO DATA", good... Wait- only 33 minutes record time available? Erase all again. Says only 33 minutes available- but I just KNOW it can record 2.5 hours in highest quality- maybe that means it is 33 minutes until it splits the file into 4 GB segments for FAT32? Well, no time to diagnose, got to go backstage and get dressed. Show starts- Camera op turns on camera and Bang, quits after 33 minutes. Out of memory before end of Act 1. AAAaaaughh!
So... apparently the TM700 sets an internal flag and "hides away" files that have not been downloaded by HD Writer AE. So when you "erase all" in camera, they are NOT erased (even though everything appears to be gone in playback mode). Files are gone, but not forgotten! And still using up memory.
Even AFTER downloading everything through HD Writer this time, then "erase all" in camera- nothing visible in camera but STILL only 33 minutes available! Which was definitely not the behavior a few days before- no idea why. I had to do "Menu/Setup/Format Media/Builtin Memory" to wipe memory and restore the normal 2 hr 45 minutes recording time in 1080p60. Sigh...almost makes me nostalgic for tape.
So, I guess it was "pilot error", lesson learned (reformat when time remaining not as expected). Didn't understand the camera as well as I thought. I would have thought you can just erase flash... I thought "reformat" related to writing sector boundaries on physical spinning-platter hard drives. Grumph.
