robot909
I'm experimenting with capturing a live feed from the HVX into FCP. I searched, but did not find the answer.
So far, I was able to stream in 1080 and 720 modes but I have to select "non controllable device" under "device control" to be able to record, otherwise, I get a "End Of Tape, recording aborted etc.." message. Any way to fix this issue?
The "non controllable device" recording works, but it ignores the time code from the HVX (which I have set to "free run"). Is there any way to record a live feed and keep the free run time code from the HVX?
Also, I tried streaming 480i just to test, but the HVX only streams that format while in TAPE mode? Can't get it to stream 480i in P2 mode. Any ideas?
Thanks!
Thanks!
