Devin Toselli
Good day guys...
i have had a problem for a while was wondering if you might have sujestions...
the problem is.
that i can not capture from my Cannon XM2 onto my external hard drive using FCP. however if i capture onto my power book's hard drive i do not encounter this problem.?
i enitially thought this was due to not enough ram but now i am up too 1.5Gb and it persists
equipment:
Cannon XM2 (i belive in the states it is called some thing different HM2?)
power book G4
Final cut 5.1.4
Lacie hard drive with fire wire 800.
the problem seems to be with the connection of the vt deck(XM2) to FCP capture log...
it slowes down and dose not read properlly also if it dose conect when i begin to capture it will capture like 5-15 frames and then stop and look for time code...
if i repeat this onto my computers hard drive with the hard drive connected it will give the same problem even if the hard drive has been unmounted...
if i repeat with the hard drive disconected and off it works perfectly so the problem lie's with the hard drive but what i do not under stand???????
any sujestions would be appretiated....
over and out Devin............
the problem is.
equipment:
power book G4
Final cut 5.1.4
