Capture Footage from VHS tape into the DVX100
This is actually the best way to go. This way, you get a solid digital copy of your VHS footage. That allows you to log and capture, and then go back later and recapture from a batch list/sequence if necessary.
If the tape is old and the control track has been chewed up a bit, you may see the picture roll. At that point, the signal should be passed through a time-base corrector (strips and replaces the control track info, which stabilizes the image).
Be advised that copyright and copy protection rules apply. The camera will not recognize a signal with SCMS encoded. If you are trying to dub footage for which you don't have the rights to copy, edit, etc., you're breaking the law.
