Can't install Magic Lantern on 60d
raizman
I just got a 60d and I'm trying to install Magic Lantern. I've followed the procedure exactly as described.
1. the camera has the latest firmware 1.0.9
2. I low level format the sdhc card (I've tried two different brands of cards)
3. I copy the magiclantern.fir onto the card
4. I insert the card back in the camera and update the firmware. All I get is this message:
Firmware Update Program
Update file cannot be found. Please check the memory card and reload the battery and try again.
The camera is locked up and I have to eject the battery to get it running normally again. I keep trying all the steps over and over and I get the same message and the camera locks up.
Can anyone suggest a solution?
Thank you so much.
weird, i did it yesterday with alpha 12! took the firmware and put it onto the sd (transcend class 10 8GB) and it updated to ML!
