Can't get DVC-PRO HD in recording setup!
pstudios
What up everyone? Can anyone help. I just got an HVX 200 and when I go to the recording setup menu, in the 480i Rec Mode selection, only DV, DVC PRO, and DVC PRO 50 comes up?
Where the H*^& is DVC PRO HD at? Can some someone help?
Is my camera set wrong? I have in an 8GB P2, and when I move up the Rec Format P2 past 720/60p, the 480i Rec Mode selection stays blue at DVC PRO 50. I have searched the menus up and down, left and right no luck!
? Where is DVC PRO HD?
Please help...
Aaron
When you set the camera to any of these:
1080i 60i
1080i30p
1080i24p
1080i24pa
720p60p
720p30p
720p24p
720p30pn
720p24pn
you are by default shooting DVCproHD.
No guys! I understand shooting 480i isn't DVC PRO HD, however I was referring to the menu option under recording setup. The media is already set to P2 not tape!
I am just saying that I see DV, DVC PRO and DVC PRO 50 and not DVC PRO HD under that option and asking how can I get the DVC PRO HD option to come up and work?
Thanks...
Aaron
Your recording setup is still set for 480i, a resolution that's not supported by DVCProHD. If you change the vertical resolution to either 720 or 1080, then the camera will use DVCProHD.
Please help...
Aaron
with a 480i rec mode on you wont' see dvcpro hd as an option. shoot in hd and you will. there is no hd 480i.
