It looks like the trandcend worked. I had the same problem.
You should be able use either card to extract the ML to to use now at this stage.
Dont forget to use eoscard or nothing will work.
You can use ML with SDXC, but you can't do the first install step.
For Mac, use MacBoot.
No get the latest firmware from the canon site.[/QUOTE
I went to the Canon Canada website and the latest version they got for my T3i is 1.0.1. Where do I get that 1.0.9 or even the 1.0.8 version? I tried Canon USA and they got the same version (1.0.1).
rikitik22![]()
Hi guys - I have a problem with installing ML:
I was trying to install Magic Lantern on my T3i, but unfortunately I can't.
I even don't know where is the problem. I did this exactly like it is in INSTALL.pdf. I downloaded everything which is needed for T3i/600D. Unzipped folder is called "magiclantern-2011Jul08.600D.fw101.alex". I have Canon Firmware 1.0.1 on my T3i. I formatted SD card like it's said in INSTALL.pdf and I do the rest like I should, but I have only screen which says:
"Firmware update program - Update file cannot be found. Please check the memory card and reload the battery and try again."
Camera doesn't react after that, so only way to turn it off is to take the battery out.
I did this with Lexar SDXC 64GB 133 Class10 Card. I tied also exactly same steps with Transcend 4GB SD Card and it made something, but Magic Lantern wasn't installed. Trying again won't help - it's like that every time.
Here is picture of what is after try with Lexar SD card:
Here is picture of what is after try with Transcend SD card:
After try with Transcend SD card, after around 10-15 seconds, camera is like turned off, but it doesn't react. There is black screen after that what you see on the picture and nothing else. So after both I have to take out the battery.
This trying of installing ML on my T3i doesn't change anything. Firmware on my camera is still 1.0.1 and it's like no changes, no Magic Lantern.
I bought T3i 1 week ago on B&H. It works normal.
Did anybody have same problem or can give me advise, how can I get ML on my T3i?
Thanks for any advice.
SH
1.0.8 and 1.0.9 are for the T2i, NOT for your T2i.
Some of you people would be best off learning your camera first before trying to "monkey" around with modified firmware.
