ahalpert
Major Contributor
I'd love to see the results of a latitude test. I'm not that impressed with the color of the highlights in the high contrast shots
The new DPAF II keeps tracking your face even when you turn around.
Sometimes you'll wanna keep focus on the same person. Sometimes you'll wanna switch. Sometimes you can't tap the screen or don't want to. I'm not saying they're not doing amazing things with AF or that I won't necessarily buy one.
Now - can a fella monitor by smartphone during recording and tap to focus there? That would really spin my wheels
Full-frame f/1.4 is usually a questionable aesthetic choice. But when I go there for light or effect, it is a challenge. I buzz a lot on rapid distance changes. Very hit and miss, mostly miss unless the distance is constant.
F/4 I can handle pretty easily except approaching an object quickly or tracking along with someone at close range with slightly shifting distance.
Having good AF could also open up new types of shots I don't even attempt
But pulling manually has 2 advantages that I am loathe to give up. One is that you always know what you want to focus on and when and how fast you want to change. And you can rack in and out of focus etc. 2 is you have to monitor closely, so at least you can tell when you're missing focus. My nightmare is coming home and realizing "the camera missed" an important shot that I thought I had.
at a fast aperture like and 85mm 1.8 - 1.4...a static person sitting in a chair cropped into chest on up...2 inches forward or backward will go out
DPAF on a gimbal is a treat too! otherwise you have to measure your distance and keep that distance to a moving subject.
also...don't always think of it as "face detection" only. forget FD for a second and just place the focus square on and object and track that object.
Thanks David- that's very interesting. Sounds like it's almost perfect for what I want
Just need a slightly faster response time for changing AF and a faster and more reliable wireless connection method. Maybe bluetooth will do it - does your 1d have bluetooth?
Thanks again David
I agree for keeping an interview subject in focus it's no contest. AF all the way. And there, obviously, keep the head if it turns. But that's a literal no-brainer situation regarding WHERE to focus.
I have a focus motor on my Ronin-S, so adjusting the focus is totally doable. It just requires effort and skill that is sometimes beyond my capabilities.
agreed. great feature on the Ronin-S as i have one too. still if your shooting with a 50mm 1.4 and in tight i would still trust DPAF to keep the face in rather that chasing focus plus you have to be able to see a monitor clear enough to judge focus. many times im just focusing on "framing" and not "tripping" when on uneven terrain that im glad i leave the focus to the camera. the AF is not your brain...but if you use your brain to understand how it will work then its and incredibly powerful option IMO
When it will track an object - is that true if that object moves across your frame? I believe so based on what I've seen. what about if they leave frame and return? And how easily is the camera thrown off the object if something else passes in front of it?
lets say if you shooting someone and you background is seriously OOF...if you subject leaves the frame the camera will then go to focus on the background and when they come back into the frame it will typically focus back on them very quickly. still to keep the focus from racking to the background you would have to maybe come up with a way to trick the camera into not doing that. i dont know how to do that but there is probably a way using custom buttons to control it. maybe someone here can answer that.
From what I can tell, these issues are the marginal differences in AF performance from one brand or generation to the next.
my A7III gives me more options on how quick it will jump to a subject crossing over my shot...how fast it will rack from one subject to another when i re-asign by tapping on the LCD.
Do you have an opinion on Sony vs Canon AF quality? I think the A7SIII may have some better recording options for me. But if Canon's AF triumphs then that may be the deciding factor
this is what i had to buy to use my 1DXmkII with my iPad
https://www.bhphotovideo.com/c/prod...t_e8a_wireless_file_transmitter.html/overview
Thanks again David
lets say if you shooting someone and you background is OOF...if you subject leaves the frame the camera will then go to focus on the background and when they come back into the frame it will typically focus back on them very quickly. still to keep the focus from racking to the background you would have to maybe come up with a way to trick the camera into not doing that. i dont know how to do that or never needed to but there is probably a way using custom buttons to control it. maybe someone here can answer that.
