Isosceles Kramer
Greetings folks.
As many probably know, AVCHD can be pretty difficult to edit, with the lag and all that, so recently i decided to check out cineform neoscene, a program that converts the raw footage from the camera to more editing-friendly files.
However, when i'm fixing to import from the camera, the program can't seem to find it ("No video capture devices available right now").
Importing 'manually' with Image Mixer works just fine, but it seems Neoscene needs to import the files from the camera itself, or else i could just convert the already manually imported files.
I'm using Vista 64bit with sp1, and in device manager the camera is located under Portable Devices, as LAGRIA HF S100.
If anyone has any info on this problem, it would be appreciated.
edit: Woah! Suddenly converting the already imported .mts files works! what the...
Well here is a picture of a platypus, so you don't feel like you got cheated of your time:
The problem still stands, though.
