Canon FD adapter
Kyle McConaghy
I'm in the market for an FD to NEX e mount adapter. Has anyone used one they particularly like? It looks like the Bower one is the only sub $150 adapter on BH Photo and I'm a bit leery of the fotodiox and rainbow imaging. But maybe I shouldn't be? Thanks for our help!
Kipon is *not* high quality.
Spend the money on a Novoflex, MTF Services or Adaptimax.
You're absolutely right - Kipon is not a name brand but you won't get one of those total crap either. It fits well and feels solid. Like I've said, Bower sell rebranded Kipon for $150 -- you're paying for name brand.
Also, spending over $200 for $50 lens isn't exactly prudent. I've barely spent $200 for 6 FD lenses in great condition including couple of primes. FD lenses are small and lightweight. As long as the adapter has a good fit, you shouldn't have much of an issue.
I've only used Sony EXs and Canon DSLRs... so this will be my first adapter purchase. Pardon my ignorance! What's up with the screw in the adapters? I assume it doesn't hurt your lenses?
There are two variation of FD mount, breech-lock (older, with silver ring) and bayonet (newer all black lenses). The only different is how the lens locks on to the camera body. The "screw" is a switch for the breech-lock type that allow you to lock/open the aperture control ring so you can manually set the aperture. There are adapters that won't support both types.
Phil Bloom has called the FD series "soft." For those who are using the lenses now on the FS100, what's your verdict on that judgment?
You're referring to what page on Bloom's blog?
I believe he called them soft when used with an optical adapter (needed on a Canon EOS mount).
The optical enlarger is not needed on a NEX adapter.
Canon FD's are sharp and contrasty. They just tend to breathe a lot on full frame - less noticeable on smaller sensors for some reason.
I think it would unfair to categorize all FD lenses as soft. Yes, a couple of lenses I've tried were soft but I have used others that were sharp as Canon L series lenses or even sharper. For example FD 35-105mm that I picked for less than $40 is sharp as Canon 70-200mm f/2.8.
I'm using a rainbow imaging Canon FD adapter and find it quite adequate. The rainbow imaging EOS adapter is a piece of junk, but the FD adapter is fine. I have, also, a lot of canon glass, including the 50mm f1.4, 135mm f/2.8 and 200mm f/3.5. These are all very fine lenses that are tack sharp. Anyone who has characterized these lenses as "soft" is mistaken.
What about the sharpness of the Canon FD 1.4. S.S.C? I've read good things but haven't heard from FS100 user.
<br><br><br>
http://philipbloom.net/2010/08/20/which-lenses-to-buy/
"Avoid the Canon FD lenses. You need an adaptor with glass in it to make it work with the EOS cameras and they simply do not work well. Soft am afraid! A real shame as there are lots of affordable FD lenses out there…"
Ah the cult of Bloom . Doctor Wu is correct. Bloom was referring to the FD to EOS MOUNT adapters which have a cheap glass (plastic really) element in it when FD lenses are used with Canon DSLR's.
FD to e mount adapters have no glass in them. FD lenses were the go to lens for professionals photographers in their day. I have about 8 FD lenses. They are not soft they are sharp and work perfectly with the FS-100. There are some L series FD's that still run over $1000. They can be cinemized too by some companies.
http://www.rplens.com/products.htm
MTF makes a great FD to e adapter. Expensive.
Ah, good to know.... although I'm sure that FD glass is starting to nudge up in price now.
And Phil's ok - just like all the bigger name guys, you have to take it all with a grain of salt - any one getting prepro products has the potential for bias. He does seems to be a straight shooter though, and I don't think he's ever promoted something that wasn't quality - or trashed something that didn't deserve it.
He knows his sh#$, and his basic advice - invest in good glass before cameras - is sound from where I am.
