Hi guys
Recently I bought an EF-S 15-85mm lens, mainly as a general purpose lens for my 7D.
I couldn't find much information about how it performs on a C100 before buying it, so I decided to write a short post and share my thoughts.
I found the mechanical quality quite nice for a non L-class lens. The manual focusing ring is a bit narrow, but it turns nice and smooth. The zoom ring also turns very smooth. The optical quality is also very good, and it has a usable macro range (closeup 35cm). The image stabilizer is quite amazing. The barrel extends a fair bit though when zoomed to 85mm:
@15mm:
@85mm:
There are two main things that bother me with this lens when used on the C100:
I made two short video clips and hope they give you a rough idea what to expect from this lens (and what not :happy
http://vimeo.com/89807170 (real life test)
http://vimeo.com/89856629 (vignetting)
So as a summary:
Would I buy this lens again? YES
Would I buy this lens again if I planned to use it on a C100 exclusively? I'm not shure... probably not.
But if you have a chance to try it out, I would strongly encourage you to do so.
- Roli
@15mm:
@85mm:
- noticeable vignetting
- fairly slow with f/5.6 above 60mm
So as a summary:
- Roli
