deserttortuga
I just picked up the Canon EF 70-200mm f/2.8L IS USM for my C-100 and was doing some test shots with the Stabilizer set to Mode 2. The C100 was mounted on a tripod using the Sachtler FSB 8 fluid head. The 70-200 zoom was not supported with the tripod mount. There was no wind or other disturbances to speak of. I was shooting at 24P at 1/48.
What I noticed is that at focal length of 200mm (or in the neighborhood) the image tends to "float." Not greatly, but enough to require stabilization in post using Warp Stabilizer "No Motion" in CS6. When I turned off the stabilizer on the 70-200mm, the "floating" seemed to stop. Of course now it lacks the benefit of stabilization should a gust of wind or some other force cause momentary vibration.
Is this an inherent issue with this lens? Is there anything I can do to either lessen or eliminate the float all-together? I suppose I can rely on post to correct it, but I'd rather correct it in the field.
While on the subject, on rare occasion when I'm shooting with the Canon 24-105 the image will start to "pump" vertically. It does it smoothly and only for a bit. Again, with Stabilizer on. What causes this?
The Turtle.....
The Turtle.....
