plasmasmp
Today I did a trial with the test clips floating around with Avid Media Composer 3.0. The software supports the Canon 7D 1080p footage at 23.98 perfectly.
What does this mean?
No more transcoding with NeoScene, instead you can use the great DNxHD codec witch allows you to edit DNxHD 175x footage fullscreen in realtime on a lowly Core 2 Duo 2.2Ghz CPU.
The benefits don't end there, you can also use some effects in realtime as well depending on the speed of your computer. For those you are planning on using anamorphic lenses, you can squeeze the footage and still edit in realtime. (Imagine having 3 monitors, two dedicated to your timeline, and a third for simply 1080p editing.)
There are Media Management benefits as well. Just pop in your CF card, Import the footage, and it will be transcoded and saved on another drive at nearly the speed it would take to just dump the card to your computer directly.
Want to finish in another program or do VFX. You can easily and quckly export a Quicktime reference file of your timeline that will allow you view your edit in other programs (realtime) and not have to deal with having to make another render of your timeline until you are ready to export your finished product. It is much better than dealing with the cineform silliness.
