Canon 60D - Final Cut 6 export - Youtube?
Your image looks pretty clean to me.
Check the you-tube specs on their site for direction on best details for uploads.
We use 5000kb/s .h264 mov or mp4 usually.
Yup- I go H.264 at best settings and get prepared to wait a long time for the upload. But the final version looks sweet.
Noah
Noah
I used compressor / H264 on the link above. what would you recommend for work flow / size / settings ? curious to know
I see some videos on youtube that look great at the 360 setting.....but on my link 360 looks ok....you have to bump it up to 720 to really see
the quality
Thanks!
Well what settings are you using? I pretty much go 1080p and crank everything up to full on H.264. Huge files but worth the look.
Noah
Well what settings are you using? I pretty much go 1080p and crank everything up to full on H.264. Huge files but worth the look.Noah
I use compressor / H264 / frame reorder > off / 1920x1089 / AAC Audio / Do you fool with reverse telecaniscis ? < misspelled ..Also is compressor the best way or QT conversion ?
I generally go out QT Conversion and don't bother with Compressor. Don't need reverse whatever.
Noah
