Richard Crowley
Under normal conditions, I would agree. But your tests and symptoms indicate that you are working on the edge of viability.I had thought this might reduce the impact of warm bodies on the RF signal. Would it not?
OK, but the issue is whether the antenna wire is deployed properly (hanging straight, not bunched up, and not up against the user)I identified the system as a Shure with Body Pack T1-W and receiver T4a-W. The transmitter certainly does have an external antenna.
Although he had been wearing it inside his jacket pocket, I learned this morning that for the last several weeks he's had it clipped to his belt, although he doesn't like it there.
The gain on the transmitter is only the audio signal gain. It has nothing to do with the strength of the radio waves being transmitted. If you adjusted it up too much, you may cause it to clip or distort during normal use. Not recommended.Okay. So as I said, I increased the gain on the transmitter and reduced the squelch on the receiver. I will put a fresh Duracell 9-volt battery into the transmitter for this Sunday's service.
The squelch on the receiver only sets the threshold of where the receiver decides signal or nothing. It is true that if the squelch setting his drifted too high, the receiver will quit (mute or squelch) while it still has a viable signal available. The normal way of setting squelch is to turn it down until the receiver un-mutes (so you hear static/hiss), and then turn it back up to mute/squelch. You do this with the transmitter OFF, so that the squelch is set to reject the ambient RF noise floor.
1) If the transmitter is not putting out the design power, or not operating in the center of the channel, then you can repair the transmitter. But since service information is probably not available, and it takes specialized experience and equipment, this is probably not a viable solution.Okay, so what are we saying here? What are the things I can reasonably do to make the system less marginal? Or are there any, aside from moving the receiver to the front of the church? Which, as I've repeatedly said, I'm willing to do if there is no other choice.
2) If the receiver has drifted out of tune, it could also be re-tuned. But again that takes specialized experience and equipment. It may not be beyond the realm of possibility that there is in your congregation (or circle of friends) an old-school ham (amateur radio operator) who still works on circuits and builds and repairs his own transmitting and receiving equipment. A good "home-brewer" type of ham radio operator could possibly examine and test the rig (transmitter and receiver) and might be able to revive it.
3) Since the system (TX - RX) seems to have marginal operational sensitivity, moving the receiver closer to the transmitter would increase the received signal strength. Guaranteed by the laws of physics.
4) Replacing the system with a more modern unit would probably resolve the problems. But is it not a gold-plated guarantee. I certainly wouldn't buy anything that couldn't be returned if it doesn't help. Beware of bargain-basement wireless systems. They may operate no better than what you have now. I would be very suspicious and wary of anything < $400.
Make a little bracket (like a communion cup holder) next to his office door and put a new battery in there every Sunday morning.Ideally. But he keeps the transmitter body pack in a drawer in his locked office. It's sometimes not easy to get access to it. Which is why he has always been the one who changes the batteries. But we can develop a protocol for that.
