David W. Richardson
Chapelgrove Films
My church continues to have a problem with the wireless lapel mic our preacher wears and uses for a small portion of the service.
Quick background. The sound mixer and receiver for the wireless mic are located at the opposite end of the sanctuary from where the preacher is. We use a Shure T4a receiver and Shure T1w transmitter.
Whenever I test the mic during the week, from the same position the preacher is in when he uses it, it works fine. Range doesn't appear to be an issue -- I've worn the mic and gone completely out of the sanctuary and up to the back exit of the building itself, and still the signal worked. But all too often during the service, when the preacher reaches the part where he uses this mic, the signal is either gone or it pops in and out -- mostly out.
Last Sunday the first 3-4 seconds it was fine, then completely disappeared. While he was still using it, I raised the receiver up as high as I could hold it, I turned it every which way, changed the position of the antennae, and checked that the cables were tight. Even turned the volume knob on the receiver all the way up. Nothing helped.
We had this same problem before, but the previous two Sundays it worked flawlessly.
Someone wondered aloud if cell phone usage by members of the congregation could cause the problem. I have to admit, I don't know for sure. I believe our Shure system is older, though I'm not sure how old.
Do you folks have any experience with this? Is it possible that cell phone usage in the sanctuary could cause this signal dropout?
I'd appreciate any advice or suggestions.
Thanks!
Thanks!
