HD NORM, SD NORM, HIGH, LOW, B PRESS? If I tape outdoor activity, when the sunlight is strong AND the object is a little dark compare to the bright background, should I do the following?
1). Set shutter speed to something such as 1/120 to 1/500,
2). Use no ND filter
3). Use LOW in gamma function in order to supress contrast.
4). Adjust Master PED to something such as +15-20
5). Make sure the IRIS is bigger than F3.4
6). Then do all the routine work and shoot.
Earlier, I posted my footage, I was not happy with the details when I check it on my HDTV. I was asking what kind GAMMA adjustment I should use.
