columbus171
I was wondering how you would go about calibrating an apple or dell lcd for use on set. I know most broadcast grade crts and lcds have external controls where they can be lined up using internal bars from camera, but inexpensive hi res lcds don't have these controls. Normally when you calibrate them you use cheap software with a colour optix from companies like x-rite or gretagmacbeth.
It would be great if redcine could be used with a coiour optix to create a LUT that could be applied to camera to calibrate your LCD. Either that or it could accept .icc profiles and convert them to .LUT files for use in camera. It would mean you would also need to be able to apply a second LUT for colour grade.
Maybe there is an easier way to do this, but if I want to use a cheaper apple cinema display and don't want to fork out for a cinetal or something similar I can't think of a easy way to do it. Anyone got any ideas.
Thanks in advance for any replies.
