scorsesefan
The low light of the c80 is obviously better but my c70 just has a certain mojo due to the DGO sensor
I owned three fx3's over the years, one a7siii and one fx6. You know what I like the most about the fx3's image - it's grain structure when shooting @ 12800. It just looks so nice and film-like...Ah yes, 2019-2021. Those were the days. We were so young back then. I remember it like it was 3 years ago.
Just kidding.
For better or for worse, I don't care that much about the look of the cameras these days. I can't remember the last time I thought a camera looked so crappy I wouldn't want to use it. Except in the case of rolling shutter.
Of course, my main camera now is the FX3 which is on your "nice" list. But, for instance, I'd say that my a7iv looks a bit better in terms of dynamic range and possibly also color and detail. (Worse rolling shutter, of course.) But I've never once elected to use it for its quality. It's always a C camera for me and only takes the lead when I need to fine tune my shutter speed to defeat banding, a feature that has been inexplicably left off the FX3.
I look forward to an FX3 upgrade to get the latest Sony IBIS which is substantially improved, hopefully better autofocus, and shutter speed fine tuning. Anything else is gravy.
I don't see myself switching from Sony unless all the clients want some other brand camera, which I doubt will happen. And the more Sony gear I buy, the more true that becomes. Here's a selfie of me pre-ordering the 85GM ii and completing my set of GM primes 14mm - 135mm:
As a fellow C70 owner I can attest to that.The low light of the c80 is obviously better but my c70 just has a certain mojo due to the DGO sensor
Who doesn't enjoy looking in the hole.
I'm sure that folks who have a C70 have figured out how to rig it the way they like, even if that means bare-handing it.
C80 weighs 2.8lbs. My a7siii weighs about 1.5lbs. I can rock an a7siii with minimal accessories on a lightweight gimbal all-day (or a heavier ronin-s with dual handles).
For the BTS shoot you describe, I imagine a monopod would come in handy. Sometimes I use one with the gimbal. Or just a light stand I can pop on and off from.
But speaking of hands in front of face torture, my first gig was an assistant at the documentary company that made Joan Rivers: A Piece of Work. I think they shot on the hvx200... Their DP bare handed it for hours on end on verite shoots. He could also walk backwards with it at slow pace and look like a steadicam. Torture? Yes. Skills and endurance? Yes. Personally, I wouldn't want to shoot like that. But my long-duration gimbal shooting doesn't actually place much strain on my body. It's just tiring. Though to be fair I'm mostly doing short shots, even on a long shoot day.
Huh. I think you may be right. 120p may require a S35 crop, reading the tea leaves from info posted on Newsshooter. That would be a massive downgrade from what I had assumed. Sony for the win!What is the maximum frame rate this camera can do with full-width sampling of all pixels?
Canon is oddly quiet on that in the press release, etc.
The specs here:
Canon EOS C80 Video Camera Specifications
Discover Canon EOS C80, a compact and lightweight full-frame Video Camera ideal for filmmaking productions. Capture stunning visuals with ease and portability.www.canon.co.uk
… say:
System Frequency / Frame Rates
59.94Hz mode (59.94P / 59.94i / 29.97P / 23.98P)
50.00Hz mode (50.00P / 50.00i / 25.00P)
24.00 Hz mode (24.00P)
And then go into a heap of codecs, etc., displayed in the usual maximally confusing way.
Then, later:
Slow / Fast Motion
6K RAW: up to 30FPS
4K recording: up to 120FPS (Long GOP) / 60FPS (Intra-frame)
2K recording: up to 180FPS (Long GOP) / 120FPS (Intra-frame)
Some people seem to be assuming that that 4K/120p mode (long-GOP only, BTW – hmm) is oversampled. Why would you make this assumption? The assumption I’d make is that it’s doing a crop to get to 120p. Which would be a little cheesy at this price in late 2024, if you ask me.
INTERNAL RECORDING Cinema Raw Light 12-bit
6000 x 3164 (Full Frame)
4368 x 2304 (cropped)
XF-AVC 4:2:2 10-Bit
4K (4096 x 2160)
23.98/24/25/29.97/50/59.94
UHD (3840 x 2160)
59.94
2K (2049 x 1080)
59.94/100/119.98
HD (1920 x 1080)
59.94/100/119.98
XF-AVC 4:2:0 8-Bit
2K (2048 x 1080)
23.98/24/25/29.97/50/59.94 (24 to 35 Mb/s)
XF-HEVC S 4:2:2 10-Bit
4K (4096 x 2160)
23.98/24/25/29.97/50/59.94/ UHD 119.98p (S35 crop)
UHD (3840 x 2160)
2K 2049 x 1080)
59.94/100/119.98
HD (1920 x 1080)
59.94/100/119.98
XF-AVC S 4:2:2 10-Bit
4K (4096 x 2160)
UHD (3840 x 2160)
59.94
2K 2049 x 1080)
59.94/100/119.98
HD (1920 x 1080)
59.94/100/119.98
XF-AVC 4:2:0 8-Bit
2K (2048 x 1080)
Canon EOS C80– 6K Full Frame & SDI - NewsshooterCanon has unveiled the EOS C80, a follow-up to the C70 that was announced almost 4 years ago. Just like the C70, the C80 was designed to be a camera
www.newsshooter.com
Yeah, tempting, but I still would like to have seen a Canon implement a cinema camera in an fx3 style body....As a fellow C70 owner I can attest to that.
But the C80 looks tempting. Maybe my GAS will run out of air before the November release.![]()
Good catch. No CFexpress. Might explain those codec limitations.Part of the limitations of the internal recording specs is from the data rates needing to work with SD Cards (rather than CFExpress).
I do not really understand the difference between an FX3 or an A7sIII in terms of "cinema". The images seem to be identical. Yes they give some more video tools on the FX3 but in my mind, the term "cinema" is being stretched a bit, no? Sort of like the term "film look". Canon doing this would be an R5 II with more heat management? Just seems like splitting hairs and what the makers decide to include on the small bodies.Yeah, tempting, but I still would like to have seen a Canon implement a cinema camera in an fx3 style body....
The differences between the image of the fx3 and a7siii is subtle but noticeable to me upon closer inspection. I've heard that Sony responded to complaints about users wanting to match their fx3's more closely to fx6s so they implemented a more organic noise pattern in the fx3. IMO the fx3 image looks less sharpened and digital than the a7siii. Just an opinion...I do not really understand the difference between an FX3 or an A7sIII in terms of "cinema". The images seem to be identical. Yes they give some more video tools on the FX3 but in my mind, the term "cinema" is being stretched a bit, no? Sort of like the term "film look". Canon doing this would be an R5 II with more heat management? Just seems like splitting hairs and what the makers decide to include on the small bodies.
To me, the term cinema should include a look that is above normal mirrorless cameras. Just like Cine lenses should look better than still lenses that cost a fraction of the price.
I think this may be because the a7siii has noise reduction built in and the fx3 doesn't??The differences between the image of the fx3 and a7siii is subtle but noticeable to me upon closer inspection. I've heard that Sony responded to complaints about users wanting to match their fx3's more closely to fx6s so they implemented a more organic noise pattern in the fx3. IMO the fx3 image looks less sharpened and digital than the a7siii. Just an opinion...
Agree with you there. I’m the first one to admit that balancing the C70 on a gimbal is a pain in the behind. The FX3 looks more effortless.Yeah, tempting, but I still would like to have seen a Canon implement a cinema camera in an fx3 style body....
Hmm. I wonder what would account for the price difference. In the US that would make the fx3 the equivalent of about $1800 USD!Agree with you there. I’m the first one to admit that balancing the C70 on a gimbal is a pain in the behind. The FX3 looks more effortless.
I forgot to mention that the FX3 is 1/3rd the price of a C80 here in Japan. (JPY 30k vs 90k.) The FX6 is about 85k.
@scorsesefan Apologies, I left out a. zero from "FX30". To clarify: The FX30 is 30k, the FX3 is 45k and the FX6 is 85k (JPY).Hmm. I wonder what would account for the price difference. In the US that would make the fx3 the equivalent of about $1800 USD!
