C300: C70 runtime with BP-A60
SWILD24
I know Canon states that you'll get upwards of 350 minutes (almost 6 hrs) with a BP-A60, but what do you get?
When you fully charge a BP-A60 and then turn the C70 on, how many minutes do you see on the display?
Thanks for posting this.
I just bought a Blueshape BP-A60 and I'm only seeing 236min on my screen when fully charged.
It says on the battery that it's a 6700mAh 96Wh, but I'm starting to wonder if the C70 is just reading it wrong, or if the battery doesn't have the juice it says it does.
I wouldn't be surprised if it had less juice. I also wouldn't be surprised if the time estimates are wrong.
Unless ya really need D-TAP out, I would opt for a used OEM Canon over a new third party battery. I've probably run 100s and 100s of cycles with the C300ii and never had an issue. The batteries are expensive but they are built well and they're reliable.
