Pierre-luc Boucher
I'm trying to set up a quick way to work with proxies (directly from c500 CF cards) and Raw or Prores 4444 (from odyssey7q) files on DaVinci Resolve.
The time code matches but I can't find the way to name the clips the same way in both the odyssey and the c500. Odyssey has 8-10 characters and digits and C500 has 2 characters and 4 digits. Also, Odyssey 7Q often splits Prores files in multiple clips this makes it impossible to reconnect.
Davinci resolve doesn't recognize the footage when I try to replace. Instead, I have to manually rename all the clips in Finder. Then, when i've imported the XML from Premiere Pro I choose to connect to the Prores Footage and it works. So my question is, how do I do this without having to manually rename the clips?
Is there a different way to easily replace your proxies in Davinci after they''ve been edited on fcp or Premiere?
