Doug_EX
Thanks! I wasn't aware that it only outputs 10bit RAW.I forgot that you can't actually crank the ISO on the Blackmagic. I will shoot a decently lit scene at 6400 on a C300 MKII and not feel so bad. At 12,500, the image starts to fall apart in an obvious way even at 1080p. But it is useable if you want it. This is with the in built noise reduction on the C300 MKII, though. In RAW, you see noise at 800 ISO. My guess is that you would just start using the internal recording at the high ISO so that you didn't have to do as much work in post with noise reduction.
Also, in case you didn't know, the C300 MK II RAW is 10bit.
