Firmware Version 1.0.5.1.00 incorporates the following fix:
1. Fixes the phenomenon in which the image stabilization function of some lenses*1 may not operate under certain combinations of settings such as when set to slow & fast motion recording mode.
https://www.usa.canon.com/internet/...t/details/cameras/cinema-eos/eos-c300-mark-ii
*1EF 35mm f/2 IS USMEF 100mm f/2.8L Macro IS USMEF 200mm f/2L IS USMEF 300mm f/2.8L IS USMEF 300mm f/2.8L IS II USMEF 300mm f/4L IS USMEF 400mm f/2.8L IS USMEF 400mm f/2.8L IS II USMEF 400mm f/4 DO IS USMEF 400mm f/4L DO IS II USMEF 500mm f/4L IS USMEF 500mm f/4L IS II USMEF 600mm f/4L IS USMEF 600mm f/4L IS II USMEF 800mm f/5.6L IS USMEF 16-35mm f/4L IS USMEF 24-70mm f/4L IS USMEF 24-105mm f/4L IS USMEF 28-135mm f/3.5-5.6 IS USMEF 28-300mm f/3.5-5.6L IS USMEF 70-200mm f/2.8L IS USMEF 70-200mm f/2.8L IS II USMEF 70-200mm f/4L IS USMEF 70-300mm f/4-5.6 IS USMEF 70-300mm f/4-5.6L IS USMEF 70-300mm f/4.5-5.6 DO IS USMEF 75-300mm f/4-5.6 IS USMEF 100-400mm f/4.5-5.6L IS USMEF 100-400mm f/4.5/5.6L IS II USMEF 200-400mm f/4L IS USMEF-S 17-55mm f/2.8 IS USMEF-S 17-85mm f/4-5.6 IS USMFor your information, this firmware also includes the changes in Firmware Version 1.0.4.1.00 released on July 28.Firmware Version 1.0.4.1.00 incorporates the following improvements: 1. Adds Canon Log 3.*12. Reduces Canon Log 2 noise in dark areas.3. Enables magnification to be used even during recording.*24. The following features are enabled when these lenses are attached: CN7x17 KAS S/E1*3, CN-E18-80mm T4.4 L IS KAS S or CN20x50 IAS H/E1*3.- Enables autofocus using the Dual Pixel CMOS AF function. (Not applicable to the CN20x50 IAS H/E1 lens)- Enables the joystick on the camera's grip unit to be set to operate the zoom.- Enables control of iris to be set to manual operation, and control of focus, zoom and iris using the separately-sold Remote Controller RC-V100.- Enables automatic aperture and push auto iris functions.- Enables retrieval of metadata, such as the model name and the focal distance of the lens attached, and display of metadata on the camera,5. Enables Dual Pixel Function when these lenses are attached: CN7x17 KAS S/E1 lens, CN-E18-80mm T4.4 L IS KAS S lens or any of the EF cinema prime lenses.6. Adds peripheral illumination/chromatic aberration correction for the following lenses:- COMPACT-SERVO lenses: CN-E18-80mm T4.4 L IS KAS S- CINE-SERVO lenses: CN20x50 IAS H/E1- EF lenses: EF 35mm f/1.4L II USM, EF 50mm f/1.8 STM and EF-S 18-135mm f/3.5-5.6 IS USM.7. Enhances menu operations so that settings related to resolution/color sampling, etc. are retained to the extent possible when changing recording settings such as the frame rate. 8. Supports ACESproxy (ACES 1.0).9. Alleviates the black-dot phenomenon that appears in the periphery of high-brightness light sources.*1 Gamma information will not be shown correctly in the metadata of clips filmed on the Canon Log3 Gamma setting included in Firmware Version 1.0.4.1.00 and above when using the bundled software application Canon XF Utility 3.0 or earlier. Therefore, we recommend our customers install Canon XF Utility 3.1. The installer for this application has already been released. Canon XF Utility 3.1 for Windows*2 "Face detection and tracking" and live view display using Browser Remote do not work when magnification during recording is On.*3 The lens firmware also needs to be updated.Caution:- You cannot perform the firmware update using CFast 2.0 cards. Please use a commercially available SD/SDHC/SDXC memory card that is 64MB or more for the firmware update. - Firmware version 1.0.5.1.00 is for updating Cinema EOS C300 Mark II cameras running firmware version 1.0.0.1.00 - 1.0.4.1.00. If your camera's firmware is already version 1.0.5.1.00, it is not necessary to update the firmware. Once the camera is updated to the latest version, it cannot be restored to a previous version.Preparations for the Firmware Update:After the Firmware update has been performed, the camera's menu and custom picture settings will be reset. It is recommended that users save their menu and custom picture settings as settings data to an SD card, separate from the one that will be used to carry out the update, before starting update operations. This saved data can be loaded into the camera and the settings can be changed after the update has been completed. For further information on this, please refer to the section in the unit's Instruction Manual titled "Saving and Loading Camera Settings".The downloaded folder contains the firmware (file name: VLB5.FIM / file size: 42,663,968 bytes), and instructions on the firmware update procedures (a PDF file in five languages: Japanese, English, French, Spanish and Simplified Chinese). Before starting the firmware update operations, please be sure to carefully confirm your understanding of these instructions.The following things are required to perform this firmware update:1. A Cinema EOS C300 Mark II / EOS C300 Mark II PL camera body2. A computer (OS Requirements: Windows 10, Windows 8.1, Windows 8, Windows 7 SP1)3. A 64 MB or higher-capacity SD/SDHC/SDXC memory card (both commercially available)4. An SD card reader/writer (commercially available) or an SD card slot built into the computer5. A fully charged battery pack for the camera6. Compact power adapter bundled with the camera7. The firmware (the downloaded file)HistoryChanges in Firmware Version 1.0.4.1.00:1. Adds Canon Log 3. *12. Reduces Canon Log 2 noise in dark areas.3. Enables magnification to be used even during recording.*24. The following features are enabled when these lenses are attached: CN7x17 KAS S/E1*3, CN-E18-80mm, T4.4 L IS KAS S or CN20x50 IAS H/E1*3.- Enables autofocus using the Dual Pixel CMOS AF function. (Not applicable to the CN20x50 IAS H/E1 lens)- Enables the joystick on the camera's grip unit to be set to operate the zoom.- Enables control of iris to be set to manual operation, and control of focus, zoom and iris using the separately-sold Remote Controller RC-V100.- Enables automatic aperture and push auto iris functions.- Enables retrieval of metadata, such as the model name and the focal distance of the lens attached, and display of metadata on the camera,5. Enables Dual Pixel Function when these lenses are attached: CN7x17 KAS S/E1 lens, CN-E18-80mm T4.4 L IS KAS S lens or any of the EF cinema prime lenses.6. Adds peripheral illumination/chromatic aberration correction for the following lenses:- COMPACT-SERVO lenses: CN-E18-80mm T4.4 L IS KAS S- CINE-SERVO lenses: CN20x50 IAS H/E1- EF lenses: EF 35mm f/1.4L II USM, EF 50mm f/1.8 STM and EF-S 18-135mm f/3.5-5.6 IS USM.7. Enhances menu operations so that settings related to resolution/color sampling, etc. are retained to the extent possible when changing recording settings such as the frame rate. 8. Supports ACESproxy (ACES 1.0).9. Alleviates the black-dot phenomenon that appears in the periphery of high-brightness light sources.*1 Gamma information will not be shown correctly in the metadata of clips filmed on the Canon Log3 Gamma setting included in Firmware Version 1.0.4.1.00 and above when using the bundled software application Canon XF Utility 3.0 or earlier. Therefore, we recommend our customers install Canon XF Utility 3.1. The installer for this application has already been released. Canon XF Utility 3.1 for Windows*2 "Face detection and tracking" and live view display using Browser Remote do not work when magnification during recording is On.*3 The lens firmware also needs to be updated.Changes in Firmware Version 1.0.3.1.00:1. Supports EF-S 18-135mm f/3.5-5.6 IS USM, an EF lens to be released in late March, 2016. (Please note that the EF-S 18-135mm f/3.5-5.6 IS USM lens does not function with previous firmware versions for the EOS C300 Mark II/EOS C300 Mark II PL.)Changes in Firmware Version 1.0.2.1.00:1. Corrects the size of the browser remote operation screen on an iOS device running iOS 9.2. Fixes a phenomenon in which the metadata of video clips recorded in RGB444 10 bit is displayed in 12 bit.3. Modifies the display when a signal to the GENLOCK terminal cannot be synchronized; the GENLOCK icon no longer disappears, but blinks instead.Changes in Firmware Version 1.0.1.1.00:1. Fixes a phenomenon in which there are skipped frames in footage recorded in slow motion. Affected frame rates are:- 4K recording at 24.00P and 23.98P- 2K/HD recording at 29.97P, 25.00P, 24.00P, and 23.98P
