S surebll Active member Jul 7, 2013 #1 My C300 fan has become almost unusable. The Fan is so loud, is there a way to fix this problem. Besides using a Boom Mic.
S surebll Active member Jul 7, 2013 #2 Ok just took some canned air and blew it through the Air Intakes. That seemed to work. It's a bit better now.
S Shawnvfx Well-known member Jul 7, 2013 #3 C100 is the same, but changing it to automatic seems to work.
S surebll Active member Jul 7, 2013 #4 Shawnvfx said: C100 is the same, but changing it to automatic seems to work. Click to expand... What's that?
N Nicholas DK Member Jul 7, 2013 #5 There is an automatic fan setting on the C100 which only turns on the fan when it's needed so the fan doesn't run constantly.
Erik Naso Veteran Jul 7, 2013 #6 This works very well. I dont think the fan has come on yet after I set it to automatic.
Darren Levine Veteran Jul 7, 2013 #7 my fan comes on frequently, but the only time i usually notice it is if it's right next to my face, it's a built in cameraman cooler
D DavidAC Member Jul 8, 2013 #8 Also take note that if you have the C300 viewfinder extended (pulled back, so as to put it at an angle) the fan is much more audible. Slide it into a locked position (most compact), and there is less noise.
