C200: C200 vs c300 Weight and Size difference?
c200 body is lighter and smaller. The exact weights of each camera are available in several places online. including canon's official spec pages for the cameras.
Thanks I just checked the info in Canon.com but actually C200 is heavier but slightly smaller
C200: Approx. 5.7 x 6.0 x 7.0 in. (144 x 153 x 179mm) Approx. 3.2 lb. (1430g)
C300II: Approx. 5.9 x 7.2 x 7.2 in (149 x 183 x 183 mm) Approx. 2.5 lbs (1125g)
they are about the same I think will be hard to notice any deference at all.
from the manual:
c300 mark2
•Weight **
Camera unit only: 1,770 g (3.9 lb.)
Camera with grip unit and monitor unit***: 3,085 g (6.8 lb.)
Camera with grip unit, bracket, handle unit and monitor unit***: 3,435 g (7.6 lb.)
**All weights are approximate.
***Working configuration includes also battery pack (BP-A30 x1), recording media (CFast card x2), and unit cables (x2
c200:
•Weight
Camera unit only: 1430 g (3.2 lb.)
Camera with handle unit, LCD monitor, LCD attachment unit, camera grip, microphone holder, eye cup and
hex socket head bolt (x1)
: 2,745 g (6.1 lb.)
c200b:
Camera unit only: 1,335 g (2.9 lb.)
Configuration with thumb rest and microphone holder
: 1,630 g (3.6 lb.)
also battery pack (BP-A30), recording media (CFast card), and unit cable)
He looked up the c100 mark ii's specs it seems.
Worth noting that the c200 is the only one with XLRs on the main body. The c100 i/ii and c300 i/ii both require a separate unit for sound, and more weight.
