Has anyone had issues with your c200 detecting your cfast card? I have the 512gb EgoDisk cards and it could be an issue of using those specific cards. I had done some testing at home and there was never any issues that I can recall, but they were short test. Went out to shoot some more video at an event to do more testing and sometimes when I would switch modes to using the SD cards for 120fps, and from 24 to 60 Raw, the card would show up red at the top. Once it said "check the media" or something like that. Sometimes I would just turn it off and back on and that would fix it, other times I would pop it out and put it back in.
It was also very, very humid and about 90 degrees outside as well. So I didn't know if that was the possible reason for that, if it was trying to disengage the cards after getting so hot when it was switching back to that mode.
Let me know if anyone else has came across this issue at all or if you've had nothing but sucess using the 512gb EgoDisk cards. It normally only took a moment to fix, but for run and gun situations the boot up time or restarts can cause you to miss a shot if you're switching modes too much.
Thanks!
Thanks!
