https://www.usa.canon.com/internet/...cinema-eos/eos-c200?subtab=downloads-firmware
Firmware Version 1.0.1.1.00 incorporates the following fix:
1. Fixes a phenomenon in which the start time code is not correctly displayed when MP4 clips captured at 59.94P/50.00P frame rate are imported into NLE software.
*RAW clips are not affected.
Caution:
- You cannot perform the firmware update using CFast 2.0 cards. Please use a commercially available SD/SDHC/SDXC memory card that is 128MB or more for the firmware update.
- Firmware version 1.0.1.1.00 is for updating Cinema EOS C200 cameras running firmware version 1.0.0.1.00. If your camera's firmware is already version 1.0.1.1.00, it is not necessary to update the firmware. Once the camera is updated to the latest version, it cannot be restored to a previous version.
Preparations for the Firmware Update:
After the Firmware update has been performed, the camera's menu and custom picture settings will be reset. It is recommended that users save their menu and custom picture settings as settings data to an SD card, separate from the one that will be used to carry out the update, before starting update operations. This saved data can be loaded into the camera and the settings can be changed after the update has been completed. For further information on this, please refer to the section in the unit's Instruction Manual titled "Saving and Loading Camera Settings".
The downloaded folder contains the firmware (file name: VNC1.FIM / file size: 36,928,128 bytes), and instructions on the firmware update procedures (a PDF file in five languages: Japanese, English, French, Spanish and Simplified Chinese). Before starting the firmware update operations, please be sure to carefully confirm your understanding of these instructions.
The following things are required to perform this firmware update:
1. An EOS C200 or EOS C200B camera body
2. A computer (OS Requirements: Mac OS 10.7 - 10.12)
3. A 128 MB or higher-capacity SD/SDHC/SDXC memory card (both commercially available)
4. An SD card reader/writer (commercially available) or an SD card slot built into the computer
5. A fully charged battery pack for the camera
6. Compact power adapter bundled with the camera
7. The firmware (the downloaded file)
Canon C200 Camera Body with EVF, LCD & Grip 2215C002 $7499
Canon C200B Body (No EVF, LCD, Grip, or Handle) $5999 IN STOCK
Canon C200B Complete Kit $7499 IN STOCK
C200 24-105mm II Lens Kit 2244C002 $8399
Canon C200 Body + 18-80mm Compact-Servo Lens Kit $12598.05
Canon C200B Body + 18-80mm Compact-Servo Lens Kit $11,198.05 IN STOCK
Canon C200B Accessories $199 - $699 IN STOCK
Canon BP-A30 3200 mAh Battery $299 IN STOCK
Canon BP-A60 6400 mAh Battery $499 IN STOCK
Canon CG-A10 Dual Battery Charger $499 IN STOCK
Caution:
