It was shot in 50i and then slowed down to 50%.Nice work, how did you shoot the slow motion?
Go pro black.Loved it. How did you shoot underwater with the C100??
I use Flycam 3000 for some shots with Canon 17-55mm f/2.8 IS, 90% of the footage was shot with Canon 50mm f/1.2 L, for slow motion I shoot in 50i ans slow it to 50% in NLE, all color corrections and grading I do in NLE with build in tools(Curves, Color, HSL atc)Really Nice Work! You are getting the most out of the C100. Did you use a Steadycam? or all the shots are just with a shoulder rig? also, will be great to hear which lenses you used? and your post workflow, any plugins?
I use Flycam 3000 for some shots with Canon 17-55mm f/2.8 IS, 90% of the footage was shot with Canon 50mm f/1.2 L, for slow motion I shoot in 50i and slow it to 50% in NLE, all color corrections and grading I do in NLE with build in tools(Curves, Color, HSL atc)
I use flycam with C100 + audio handle + 17-55mm with no problem.Hey,
Thanks for info, the 50mm 1.2 is a sweet lens!
Never heard about Flycam, googled it, and it seems really cheap but only supports up to 5 pounds, so barley the weight of the camera+zoom...do you strip the camera as much as possible when working with it?
From mentioning HSL I gather you're using Adobe Premiere?
Thanks again.
Which model Flycam are you using?I use flycam with C100 + audio handle + 17-55mm with no problem.
