C100: C100 over cranked to 20k and cleaned up in post. Amazing performance
You mean ISO @ 20000 not over cranked. Over cranking comes from the term for over cranking a film camera to shoot more FPS, when these are played back at 24fps you get slow motion.
HOWEVER, onto your shots - for 20,000 iso, its very clean.
What Noise Filter did you use? I always have trouble with denoise, the only one i ever had access to is the AE native Remove Grain. Following the 'multiple passes at low settings' principle but I'm still not very savvy on the process.
How did you manage the slo-mo, doesn't the c100 max out at 30p?
Super clean and lovely camera movement btw.
I used a plugin for AE called Neat Video. It lets you adjust different settings in the lows mids and highs so you can tweak it based on your image.
Believe it or not thats all shot at 24p, I just used super slow movements with the jib. Theres one part when a truck rolled by very slowly so it probably just gives off the effects of being shot in 60fps or something
