Do you leave it on all the time or only activate above certain ISO?
I haven't had time to experiment much, but I do know that if you turn it to 0 C-log gets noisy.
Are you black balancing? Shooting in the dark? The bottom line for Canon log is even though its extremely clean at high ISO's it needs some light in there. It was never intended to take into a dark place and just crank it to 20,000.
Out of the box, how good / bad is the C100 really?
Very constructive comments. Thanks!This C300 camera is good and people boast that they need zero lights. However, we definitely need some amount of lights for this camera to expose well.
I found that for the C300 Black balancing (ABB) is the key as Noel says. In one scene, I had ISO 320 set and I was searching for the leopard for several hours. When I finally could find it, the light levels had gone down. I quickly setup my tripod, cranked up the ISO to 5000 and started filming. I regret it because I didn't do black balancing and the noise is higher. Unfortunately the black balancing takes time and in wildlife it becomes a difficult proposition. However, I try to do black balancing all the time. At ISO 20000, I tried filming in moonlight, but this camera needs some more light. I have used torch light and also spot light to film nocturnal behaviour of leopards, jackals, porcupines etc. This behaviour cannot be seen in daylight. If the torch light or spot light doesn't fill the entire frame, then you find lot of noise in the dark areas and that makes the viewing experience unpleasant. Else, the noise will not be noticed by the viewers.
Because of the C300 I spend more time in the field even at low light and no light. I feel it is making me a better naturalist as I am observing behaviours which I hadn't seen earlier.
