A thousand hours is a lot. Did they capture with it? And is it a 100a or 100b. $900 is pretty cheap. But I definitely would not consider it if it is a 100a.
its just the dvx100 also what is wrong with the dvx A. just wondering? and im not sure what capture is. but think he did
i think 1000 is a steal!
Given the hours I would say it is worth much less. Probably 750-900.
Okay, there is a way to use the DVX100 series camcorcorders without putting any wear on the heads. You can connect a cheap camera as a slave unit to the DVX so that all of the wear is on the slave. There is no loss of quality and all the data flags from the DVX are recorded onto the tape the same as if the tape was in the DVX. That is one of three ways a slave can be used with a DVX100 series camera.
Here's how to do it:
http://www.dvxuser.com/V6/showthread.php?t=142362
What I did was buy one of those "fanny packs" with a belt. I put my little MiniDV camcorder in the fanny pack and connect it to my DVX100B with a 6 ft. Firewire cable. I just have to be careful not to get the cable caught on anything as I move around.
and you look cool at the same time.
