hey guys, this is the running diary of me building a new computer for editing GH1 footage. for the first post i'm just going to c/p a post i made on a tech forum. it's the pre-production post
I ask questions in there but you don't have to answer 'em (unless you want to), they're for the computer forum duders. I'll be posting the later stages of the process as it goes along. Thought this might be of some benefit to you guys.
Hey guys,
so I currently edit AVCHD 1080i video on my Sempron laptop. It's not fun. So I need to build an editing rig... but I want it very very cheap (and good still LDO!)
1. What YOUR PC will be used for. That means what types of tasks you'll be performing.
video editing mainly, photoshop work, and 3d stuff
2. What YOUR budget is. A price range is acceptable as long as it's not more than a 20% spread
$400
3. What country YOU will be buying YOUR parts from.
america
4. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy, ATI-Fanboy, nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc, etc, etc, you get the picture.
cheap, reliable, hassle-free
5. If YOU intend on using any of YOUR current parts, and if so, what those parts are.
keyboard, mouse, monitors
6. IF YOU have searched and/or read similar threads.
yes
7. IF YOU plan on overclocking or run the system at default speeds.
default, hassle free as much as possible
8. WHEN do you plan to build it?
asap
OK, so here's what I've come up after researching today (which was very very fun):
CPU: AMD Phenom II X3 710 2.6GHz
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103648
$99
MOBO: ASRock K10N78
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157159
$64.99
RAM: OCZ 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066
http://www.newegg.com/Product/Product.aspx?Item=N82E16820227362
$48.99
CASE: Rosewill R5604-TBK 0.8mm Japanese Cold Rolled Steel Screw-less Dual 120mm Fans ATX Mid Tower
http://www.newegg.com/Product/Product.aspx?Item=N82E16811147033
$44.99
HARD DRIVE: HITACHI Deskstar P7K500 0A35415 500GB SATA 7200 RPM 16MB
(http://www.newegg.com/Product/ProductReview.aspx?Item=N82E16822145215)
$53.99
PSU: SeaSonic SS-400ET 400W ATX12V V2.2 / EPS12V V2.91 80 PLUS Certified
http://www.newegg.com/Product/Product.aspx?Item=N82E16817151061
$49.99
or
Antec earthwatts EA430 430W
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371006
$59.99
or
CORSAIR CMPSU-400CX 400W ATX12V V2.2
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139008
$59.99
OPTICAL: LITEON iHAS124-04 24X SATA DVD Burner
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=10010552
$31.99
total: $392.94
Before you say anything...
-I will use onboard video (Geforce 8200) for the time being planning on upgrading later
-Single hard drive is sub optimal for video editing however I plan to get two more in the future when I have more $$
-I could've gone $15 cheaper with my case but the looks difference is astounding, and I really like the look of the one above.
Questions I have:
-The motherboard (mnfr link) uses the Geforce 8200 chipset from what I can tell. The sticky on the top says to stay away from Nvidia for mobos. However, on newegg the one I picked has excellent reviews. I want to be able to install my Phenom II X3 with no problems and preferably no bios flashing.
-Is the Seasonic 400W going to be enough if I plan to later get a video card, firewire, two more hard drives, and 4GB more RAM? Should I get the Corsair or the Antec Earthwatts for $10 more?
-For $46 more I can get a Phenom II X4 940 with a Biostar TA790GXB 790GX motherboard which has onboard video of ATI Radeon HD 3300. I'd rather not spend this extra money and certain video editing things make use of NVidia but not ATI. Although it is a 3.0GHz 4core vs 2.6GHz 3core. And it gets rid of the Nvidia chipset on the motherboard, which I'm not convinced is an issue.
Hey guys,
$400
america
yes
asap
$99
MOBO: ASRock K10N78
$64.99
$48.99
$44.99
$53.99
$49.99
or
$59.99
or
$59.99
$31.99
total: $392.94
Questions I have:
