notharrylume
For my set of 6 manual nikkors which all have a 52 mm thread I think I have two reasonable budget ND options:
My GH2 is scheudled to arrive from B&H today!!!!!!!!!!!!!!!!
- Light Craft Works Fader ND MK II (8 stops) - $72
- Tiffen Glass ND filter set (.6, .9, 1.2) - $42 plus .3 $16 = $58
Light craft pros - one filter; infinite variability
Light craft cons - can get dust between lenses; can't use with lenses over 200 mm; no repeatability - no markings defining actual density; sometimes produces some kind of "X" - whatever that means
Tiffen pros - precise amount of nd - you always know how much you're adding; ability to clean all surfaces of filter
Tiffen cons - optical quality reputation not great; need to stack to get maximum density; can't get fractional density
Because I'm not going to spend $283 for a Heliopan I'd very much appreciate some knowledgable advice about the best nd solution. What do you think? Thanks for your thoughts.Light craft cons - can get dust between lenses; can't use with lenses over 200 mm; no repeatability - no markings defining actual density; sometimes produces some kind of "X" - whatever that means
