Brains - new hybrid rig
Constantinos
BRAINS is a new hybrid rig designed for DSLR cams and light weight cams.
BRAINS is a shoulder mount+hand held stabilizer+ mini dolly system all in one package.
It can be converted tool-less and in minutes from one to another offering a unique solution that comes in a small pelican case.
BRAINS includes.
- Carbon fiber tubes 1.5 inch (38,1mm) and connector units.
- One telescopic Carbon fiber tube assembly(central tube unit)
- Stage rotational support grip bracket.
- Camera stage
- One 15mm rod bracket for direct mount on stage(60mm standard)
- One extra rod bracket for additional accessories mounting.
- Carbon fiber 15 mm rods.
- Shoulder pad mount
- Monitor mount bracket
- 3 set of complete skate wheel units (each unit includes adapters and necessary brackets for direct mounting on BRAINS)
- 3 set of complete hard wheel units for smooth plain floors.
There are endless configurations you can achieve, from one handle support system, to full support shoulder system, mini dolly, and hand hel stabilizer, all in one unit, lightweight, easy to carry.
Get to know BRAINS hybrid rig- (still under development ).
Any input welcome
ready for November delivery.
Sells as a complete unit for shoulder mount, h/h stabilizer, mini dolly system,
OR
as a starter shoulder mount, that with 2 additional upgrades you can go to h/h stabilizer and mini dolly.
So you can choose your configuration needed .
Also available as a shoulder mount only BRAINS ONE.
Supports from DSLR to 8+ kgr HDcamcoders, like EX1-EX3, FUTURE SCARLET, Lightweight EPIC, AF100-101, And just about any camera in that range.
Positioning of the camera can be very moduLar, with many configurations , including monitor viewing, left angle offset possitioning for DSLR viewfinder viewing e.t.c.
probably the most rigid, modular and light weight rig out there to support all range.
Videos and photos soon
BRAINS
Steeve hello. Is it the product you care about, or you are buying websites?
The website is still under construction and will be changing soon, this is just a quick view.
Good advice - throw out your terrible flash based site and hire someone to make you normal html based site with proper design and good photos.
About the website.the server have moved yesterday new url at the bottom. Since the part of the rigs are under production, I have decided to take down the website for reconstruction and bring it up with reviews and photos of the rigs.
As for price. This is nothing like the other rigs. Design wise or quality wise.You will see for your self very soon.
If someone can find me a rig out there that can take cameras from DSLR to Epic, that can reconfigured in a mi nute to be a h/h stabilizer, and reconfigured in minutes to be a mini dolly,
that includes a ARRI compatible dovetail XY microadjustable stage, dovetail plate, and pan bearing handle assembly , with Carbon fiber 38.1 mm frame tubes, and with rod bracket and rods 15mm CF, Iam here to see.
The basic version of Brains will include a complete shouldermount that will support from DSLR to 8kgr cameras, at any configuration front mounted with or with out offset, or center over the shoulder mounted for balance on the shoulder for longer and heavier cameras, mounting plate, offset bracket, fully adjustable carbon handles, 15mm or 19 mm brack and rods for matte box and ffocus and it will fully upgrade-able to the full version . Staring price 799 euro.
The rigs are made of 6061 t6 aluminum hard anodized, and have been CNC machined from billet, they are not cheap material drill out waterjet cut brackets.
Do not compare uneven things and come into the wrong conclussions.. You will judge for your self.
Over the last year we have moved our workshop from Athens to Syros Island and a lot of changes to rigs and designs as well as taking the challenge of motion control rigs.
Thats full load for a small company, and thats why we have delayed website building and stuff. Hopefully everything will be there very soon.
there is also a new URL : www.the-running-rigs.com currently under construction that will be active very soon.
Thank you
Thank you
Are you a sponsor on this site, are they aware that you are marketing here?
