The other is an HDMI-only 60i-only unit.
David:
Can you provide more information about Stripper 1.0?
Release date? Mac? PC? etc?
Should have said that, of course, for PAL users the output is 50i and of course the Ninja supports that standard.Barry, I agree that most cameras output 60i through HDMI. In Europe, 50i is more common, and of course, we support that, which often looks the same as 25p, since it's derived from a progressive source.
Yes, this is something that seems to be getting lost in the translation along the way -- the Ninja is recording whatever the camera gives it. If the camera only outputs 60i, then that's what the Ninja will record. It can't magically synthesize 60i into something else.We do support progressive video if any manufacturers would care to output it through HDMI. It's not us causing this limitation! Any other HDMI recorder will have exactly the same limitations.
I think this is the other thing that keeps getting lost. Infrastructure for 1080/60p really isn't there yet. I know a few cameras have jumped the gun and started offering it, but I don't even think the EBU/SMPTE/ATSC groups have even standardized on a 60p broadcast format yet. Seems like people think 60p is already here, but ... not really.You would need a completely different architecture do deal with 1080p60. It's twice the data rate, and you can't cater for that with a simple firmware upgrade.
Which of the above would u buy ?
tx
But what happen if I connect a sony cx700 or panasonic tm900 to an Atomos via HDMI and the 2 camcorders are set to record in 60p ?
I guess that it does not matter becasue the camcorder HDMI will output in 60i anyway. So the Atomos would get and see an 60i signal.
But than the other problem is that that 60i HDMI output is a compressed signal...am I correct ?
So, my guess is that , with the actual technology, no matter which camcorder,dsrl or whatever we connect to the atomos (except for maybe 2 or 3 items), we will record on the Atomos a signal that in quality is lower than the one recorded directly in the camera/camcorder....
Next step should be, push the camera and camcorder manufactures to add NON compressed HDMI output signals in their cameras....
What about firewires ?
Many old HD mini dv camcorders offer firewire connections ,and firewire recorders exist...do these firewire recorders also have a problem because they get from the camcorder a lower quality sigal from te camcorder firewire output ?
Thank you
A couple of words of clarification here:
1080 60p is not a viable format because nothing supports it yet. Even if you can get it out of the camera, you can't play it back on anything. It's not a broadcast format. It's time may come, but it's time is not now. Yes, what comes out of the camera is most likely to be 60i, or 24p wrapped as 60i.
HDMI can NEVER output a compressed signal. HDMI is always uncompressed. The Ninja captures it and encodes it into ProRes, which is a visually-lossless codec - ie it looks the same as uncompressed.
Because of this, the Ninja records a signal that is BETTER than the one recorded on the camera, because it uses a better codec at a higher bitrate. Firewire ONLY carries a COMPRESSED signal. It is a completely different system to HDMI.
I hope this helps.
Dave Shapton
Atomos
If you are recording 60p on a camera that supports 1080/60p, then yes, the on oars recorder will be better than an external recorder, because the camera most likely cannot send that full 60p signal out the Hdmi port.
Bu the way, regarding the HyperDeck Shuttle, which type of hard disk will support ?
At that point, if I have to waste my money in buying something that record videos externally from the camera, in a lower quality (NOT progressive), I would also look other options at a lower price
Thank you
Well, I think part of that confusion is coming from your desire to use 1080/60p. Because that's the part that's nonstandard. 60p is not an actual video standard yet. Yes, I know some cameras have it, but it has not been codified and standardized. It is not a broadcast standard.I think that the atomos is a great idea, but I am NOT sure if right NOW its potential can be applied to any camcorder or dsrl.
Not sure I follow you, so let's be clear: the Ninja is not for DSLR users. DSLRs cannot properly take advantage of what the Ninja does, because the DSLRs do not output clean video signals, and even what they do output is low quality so it doesn't make much (if any) sense to record it. So if you want to talk about the Ninja's benefits, you should just forget DSLRs. As for camcorders -- there are millions of low-quality HDV camcorders out there, that have good lenses and good sensors and good HDMI ports on them, but are stuck with the absolutely horrible HDV format. The Ninja would give a substantial boost in image quality to anyone using an HDV camera.It seems to me that camcorder and dsrl are behind th atomos idea, and maybe due to the fact (especially for dsrl) that they want to differentiate the dsrl market from the camcorder market.
DSLRs are not camcorders. They're still cameras that happen to have a motion feature added to them. They don't do what camcorders do.Dsrl have the 4gb limit that makes them on a different level in comparison to the camcorders.
That's like saying manufacturers want you to buy both a car and a motorcycle. The DSLR is different from the video camera. The DSLR shoots stills. The video camera shoots video. DSLRs have a sort of video feature in them, but that is not the job they were designed to do.I guess manufactures want us to buy both a camcorder and a dsrl, that is why many dsrl do not even have a good useful video signal for the atomos , coming out of their dsrl.
It most definitely will not. If you want 60p, your ONLY choice is to record it internally.I am still puzzled if buying nowdays an atomos and connecting it for example to a panasonic tm900 that records in camera at 60p, would give me on the atomos a better video quality....
Sorry to bump in Barry, but I need you to make an FS100 book so I can figure out how to use it ;-) I was excited about the FS100 because of its 1080p60 slo-mo. I am naive and don't understand. Why is it is an option on the FS100 if can't use it, or do I change it on my timeline in Premiere later?Well, I think part of that confusion is coming from your desire to use 1080/60p. Because that's the part that's nonstandard. 60p is not an actual video standard yet. Yes, I know some cameras have it, but it has not been codified and standardized. It is not a broadcast standard.
Drat! Are you saying if I buy a D7000 as a B or c camera that I can hook-up the Ninja and get ProRes 422 out of it? HOw about tge GH2? I recall reading in this thread it does hdmi out?Not sure I follow you, so let's be clear: the Ninja is not for DSLR users. DSLRs cannot properly take advantage of what the Ninja does, because the DSLRs do not output clean video signals, and even what they do output is low quality so it doesn't make much (if any) sense to record it. So if you want to talk about the Ninja's benefits, you should just forget DSLRs.
I was looking at FS100, D7000 or if need be the GH2 and a VG10 three camera set-up and was hoping one recorder could bridge footage from all three. Is this viable?And even for cameras that have decent or good recording formats like AVCHD or XDCAM-EX, there are still benefits that can be gotten from using a Ninja. The Ninja records 4:2:2 color, those camcorder formats are 4:2:0. And the Ninja records in ProRes MOV format, so people who use Apple's editing systems now have the capability to directly drag and drop the footage right to the timeline, something they've never really been able to do before.
1080/60p for slow-mo isn't a problem, depending on how it's recorded. The AF100 records 1080/60p for slow-mo purposes, with playback at 24fps (2.5:1 slow-mo) or 30fps (2:1 slow mo). And that's totally compliant with all standards and works fine.Sorry to bump in Barry, but I need you to make an FS100 book so I can figure out how to use it ;-) I was excited about the FS100 because of its 1080p60 slo-mo. I am naive and don't understand. Why is it is an option on the FS100 if can't use it, or do I change it on my timeline in Premiere later?
As David already answered, there's little point (if any) in hooking a DSLR up to a Ninja (or any other external recorder). The only one that can be used at all, as intended, would be the GH2, and that has a spate of problems with its signal that make it more problematic. It has a nonstandard frame rate with a double-layer pulldown, it has garbled 4:2:2 chroma, and it has inaccurate color output. It's a $899 digital still camera, not a professional video camera, and its output was never designed to be recorded. You can run a script in post that overcomes many of these issues, but you'll still not have 4:2:2 or 10-bit. The only benefit you get from jumping through the hoops, is a less-compressed image. Which, simultaneously, takes up 10x as much space, and eliminates several useful features (such as disabling 720p mode, and the ETC mode).Drat! Are you saying if I buy a D7000 as a B or c camera that I can hook-up the Ninja and get ProRes 422 out of it? HOw about tge GH2? I recall reading in this thread it does hdmi out?
Well, again -- yes and no. Yes you can record the 60i output of any of those, but should you? In several cases, no. The FS100 already has a pretty good codec on it, and if you want to use 60p it's not going to work, the FS100 can't output 60p. The D7000 likely has a cluttered up display that's not worth recording, although I haven't tried that particular model. I would hope the VG10 has a clean output but don't know. And the GH2 can be used with it, with the above-listed complications and restrictions.I was looking at FS100, D7000 or if need be the GH2 and a VG10 three camera set-up and was hoping one recorder could bridge footage from all three. Is this viable?
Would the NEX5 work well w/Ninja? I understand it has the same sensor as VG10 and I did see it doing HDMI out here: http://www.youtube.com/watch?v=K5PCoJllJaE
(I'm seeing this as a way to use my glass on an inexpensive 3rd cam.)
