BlackMagic Cinema Camera Technology Announcements & Latest Info'
PappasArts
Continue the discussion at BMCuser.com. A new Landmine Community for Blackmagic Camera Users
For Updates: MIKOS • MLPappas on Twitter
http://PAPPASARTS.WORDPRESS.COM
http://TWITTER.COM/PAPPASARTS
http://MIKOSarts.wordpress.com
http://MIKOSarts.COM
[SIZE=+2]BlackMagic's Cinema Camera Latest News & Info[/SIZE]
Move to Digital Film
Blackmagic Cinema Camera features a high resolution sensor with wide dynamic range so it’s perfect for independent film, television commercials and episodic television production. DaVinci Resolve software for Mac™ and Windows™ is included so you can work at the highest quality and get the best results. Blackmagic Cinema Camera is both affordable and a complete solution because it includes a built-in recorder and monitoring, so it’s perfect for displacing video-only cameras for work such as sporting events, weddings, music videos and more!
Blackmagic Cinema Camera Key Features
  • High resolution 2.5K sensor allows improved anti aliasing and reframing shots.
  • Super wide 13 stops of dynamic range allows capture of increased details for feature film look.
  • Built in SSD allows high bandwidth recording of RAW video and long duration compressed video.
  • Open file formats compatible with popular NLE software such as CinemaDNG 12 bit RAW, Apple ProRes and Avid DNxHD. No custom file formats.
  • Includes no custom connections. Standard jack mic/line audio in, BNC 3 Gb/s SDI out, headphone, high-speed Thunderbolt I/O technology, LANC remote control and standard DC 12-30V power connection.
  • Capacitive touch screen LCD for camera settings and slate metadata entry.
  • Compatible with extremely high quality Canon EF and Zeiss ZF lenses.
  • Supports 2.5K and 1080HD resolution capture in 24, 25, 29.97 and 30 fps.
  • Thunderbolt connection allows direct camera capture via included Media Express software and supports live waveform monitoring via the included Blackmagic UltraScope software.
  • Includes a full copy of DaVinci Resolve 9.0 color grading software.
BlackMagic Cinema Camera Adds the timeless beauty of feature film quality
Elegant, sophisticated and jam packed with the latest digital cinema technology, Blackmagic Cinema Camera gives your work that timeless feature film look! Blackmagic Cinema Camera features an amazing 2.5K image sensor with a wide 13 stops of dynamic range for a true digital film camera. You get a built-in SSD recorder, popular open standard uncompressed RAW and compressed file formats, compatibility with quality EF and ZF mount lenses, LCD touchscreen monitoring plus metadata entry, all packed into an exciting hand held design!
Elegant Design
Cinematographers form a personal relationship with their camera for a creative partnership that can last years and span every location on the planet! Starting with a chassis machined from solid aluminum, capped with a smooth rubber front and rear for easy grip, plus a rear facing touchscreen for easy metadata entry, you get a stylish design that’s optimized for the whole post production workflow. Blackmagic Cinema Camera includes standard jack audio so there are no custom connectors!
Open File Formats
Blackmagic Cinema Camera uses standard file formats, so you don’t need to wait years for your video software to support the media! Recording native 2.5K resolution uses the open CinemaDNG format, so you get full 12-bit RAW recording quality using the built-in SSD recorder, and the benefit of industry wide compatibility. For even greater compatibility you can also choose 1080HD recording into ProRes and DNxHD compressed video formats. Blackmagic Cinema Camera is the only camera to support purely open file formats!
Enter Metadata Easily
The large capacitive touchscreen display makes it incredibly easy to log metadata directly into the camera. When you tap the display with a finger, a data entry window called the "slate" appears. This lets you enter shot information just like typing on a smartphone. This data is then stored in the files so can be accessed by NLE software when editing content later. Metadata is compatible with popular software such as Final Cut Pro X and DaVinci Resolve.
Fast Metadata Entry
Logging file metadata directly into the camera dramatically speeds up the post production process. With the Blackmagic Cinema Camera 'slate' you can enter information such as shot number, search tags, scene number, timecode and more! You can even set shot number and other data to increment automatically! Metadata is compatible with leading editing software and is fully searchable so when you're editing your project you can avoid the time consuming task of searching for specific shots!
Includes DaVinci Resolve
Blackmagic UltraScope provides technically accurate waveform monitoring with a beautifully designed computer interface. Connect Blackmagic Cinema Camera to any computer using Thunderbolt technology to display 6 live scope views on a single monitor! Use UltraScope on set or in any location for Parade, Waveform, Vectorscope and Histogram signal measurement. UltraScope includes picture view, audio level and phase monitoring!
Includes UltraScope
Blackmagic Design Cinema Camera lens chart
https://docs.google.com/spreadsheet/ccc?key=0AsEttGOlmiOTdDFtVGZoLWlfRVRIRUQ4RFViV0JJLWc#gid=0
LENS FOCAL LENGTH EQUIVALENTS ON THE BLACKMAGIC CAMERA
[TABLE="class: outer_border, width: 500, align: left"]
[TR]
[TD]2.3 X LENS FOCAL LENGTH = ##
Distagon T* 15mm f/2.8 ZE = 34mm
Distagon T* 18mm f/3.5 ZE = 41mm
Distagon T* 21mm f/2.8 ZE = 48mm
Distagon T* 25mm f/2.0 ZE = 57mm
Distagon T* 28mm f/2.0 ZE = 64mm
Distagon T* 35mm f/2.0 ZE = 80mm [/TD]
[/TR]
[/TABLE]
Price: The MSRP 2,999.99- The BMC comes bundled with Resolve 9 full license with dongle & Ultrascope software.
Release Date for first cameras to ship is expected: July 2012
To Buy BlackMagic Cinema
USA BlackMagic Cinema Camera- How to Buy
http://www.blackmagic-design.com/products/blackmagiccinemacamera/howtobuy/
UK BlackMagic Cinema Camera Purchase- How to Buy
http://www.blackmagic-design.com/uk/products/blackmagiccinemacamera/howtobuy/
[SIZE=+0]The Official Blackmagic Camera Page[/SIZE]
Blackmagic Camera Design
http://www.blackmagic-design.com/products/blackmagiccinemacamera/design/
Blackmagic Camera Models
http://www.blackmagic-design.com/products/blackmagiccinemacamera/models/
Blackmagic Workflow
http://www.blackmagic-design.com/products/blackmagiccinemacamera/workflow/
Blackmagic Tech Specs
http://www.blackmagic-design.com/products/blackmagiccinemacamera/techspecs/
Texas Media System's DVXUSER Group Buy for BlackMagic Cinema Camera
[TR]
[TD]Special Group Buy for the Blackmagic Cinema Camera for DVXUSER members.
The promotion code will be available Monday once you Like or Follow our Facebook or Twitter pages:
https://www.facebook.com/texasmediasystems
http://twitter.com/#!/txmedia
We are accepting online orders on our website and will bill as we ship cameras.
The Blackmagic Cinema Camera handles are available here.
Prepaid orders by check or wire transfer will be given priority over credit card orders. We'll have the check or wire transfer payment option enabled on Monday.[/TD]
[/TR]
[/TABLE]
[SIZE=+2]BLACKMAGIC CINEMA CAMERA VIDEOS & FOOTAGE[/SIZE]
Filmed with the BlackMagic Cinema Camera By John Brawley
1.http://vimeopro.com/johnbrawleytests/blackmagic-cinema-camera/video/40290704
2.http://vimeopro.com/johnbrawleytests/blackmagic-cinema-camera/video/40390150
John Brawley BLOG on Videos shot with the Blackmagic Cinema Camera
http://johnbrawley.wordpress.com/2012/04/17/blackmagic-cinema-camera-lets-take-it-from-the-top/
#2 Video Filmed with the BlackMagic Cinema Camera By John Brawley
DIRECT LINK: http://vimeopro.com/johnbrawleytests/blackmagic-cinema-camera/video/40390150#/video/40584879
NEW BLACKMAGIC CINEMA CAMERA 1080P FRAME GRABS By John Brawley
Leah Ungraded - Flat 1920x1080
LINK TO FRAME GRAB:http://johnbrawley.files.wordpress.com/2012/04/leah_1-20-2.jpg
BlackMagic Camera- Wider Frame Grab- 25mm at 800 ISO -by John Brawley.
http://johnbrawley.wordpress.com/2012/04/24/wider-frame-grabs/leah-wide_1_1_1_1-22-2/
John Brawley wrote:
In this setup, I used NO LIGHTING whatsoever. It’s natural only. No gels on the windows. That’s sunlight back there.
Look at how much dynamic range there is. You can see out the windows and into the black of her dress.
DIRECT LINK TO 1920x1080 IMAGE: http://johnbrawley.files.wordpress.com/2012/04/leah-wide_1_1_1_1-22-2.jpg
NAB 2012 - Blackmagic Cinema Camera First Look by Landmine Media
NAB 2012: Detailed Interview on the Blackmagic Digital Cinema Camera
NAB 2012 - Blackmagic CInema Camera First Look by by CineDigital.tv
BlackMagic's Dan May Interviewed at NAB. by FreshDV
NAB 2012: Blackmagic Design 2.5K RAW camera for $3000 By cinema5D
VIDEO: Q&A BlackMagic's Director of Sales Simon Westland.By Dan Chung-Direct Link
http://www.dslrnewsshooter.com/2012...-featured-live-on-matt-and-dans-nab-geek-out/
1920x1080P Frame Grabs Ungraded RAW & Graded in DaVinci Resolve
1920x1080 Ungraded RAW 1::
http://johnbrawley.files.wordpress.com/2012/04/untitled_1-2-2.jpg
1920x1080 Graded Frame 1::
http://johnbrawley.files.wordpress.com/2012/04/untitled_1-2-1.jpg
1920x1080 Ungraded RAW 2::
http://johnbrawley.files.wordpress.com/2012/04/untitled_1-23-21.jpg
1920x1080 Graded Frame 2::
http://johnbrawley.files.wordpress.com/2012/04/untitled_1-23-1.jpg
1920x1080 BMC Frame Grab 1:
http://johnbrawley.files.wordpress.com/2012/04/untitled_1-62-1.jpg
1920x1080 BMC Frame Grab 2:
http://johnbrawley.files.wordpress.com/2012/04/untitled_1-49-1.jpg
1920x1080 BMC Frame Grab 3:
http://johnbrawley.files.wordpress.com/2012/04/untitled_1-47-1.jpg
1920x1080 BMC Frame Grab 4:
http://johnbrawley.files.wordpress.com/2012/04/untitled_1-39-1.jpg
1920x1080 BMC Frame Grab 5:
http://johnbrawley.files.wordpress.com/2012/04/untitled_1-24-1.jpg
1920x1080 BMC Frame Grab 6:
http://johnbrawley.files.wordpress.com/2012/04/untitled_1-23-2.jpg
1920x1080 BMC Frame Grab 7:
http://johnbrawley.files.wordpress.com/2012/04/untitled_1-20-1.jpg​
[size=+1][/size]
[size=+1]BLACKMAGIC CAMERA FULL SPEC SHEET[/size]
[size=+2]OUTPUT OPTIONS- SDI TO HDMI- BLACKMAGIC DESIGN[/size]
[size=+0] For converting the BMC SDI output to HDMI[/size]
Protected Recessed Connections
Battery Converters give you the freedom to work in remote locations, on outdoor sets or at live events and still get the highest quality SDI conversion. Extending HDMI cable lengths during live production is easy as you can add a Battery Converter HDMI to SDI and use long SDI cables for your cameras. Use TVs as monitors on location with a conveniently hidden Battery Converter SDI to HDMI for amazing full HD resolution monitoring! The internal battery means your video is always protected from power outages or disconnections!
THE NEW BMCUSER.COM- THREAD CONTINUED HERE: http://www.bmcuser.com/showthread.p...mera-Technology-Announcements-amp-Latest-Info
[size=+1]Blackmagic Cinema Camera NAB pics[/size]
http://www.engadget.com/2012/04/16/blackmagic-cinema-camera-packs-feature-film-2-5k-quality-touc/
A nice chat with Dan May from Blackmagic BY LANDMINE MEDIA
NAB 2012 - Black Magic Cinema Camera by Dan Chung
NAB 2012 - Blackmagic Cinema Camera hands on by TheVerge
Blackmagic Cinema Camera - NAB 2012
The new Black Magic Design Cinema Camera - A talk with John Brawley
http://freytag-film.com/blog/artikel/talk-about-the-new-black-magic-design-cinema-camera
VIDEO: An exclusive Q and A about the new BlackMagic Design’s Digital Cinema camera with the company’s Director of Sales Simon Westland.By Dan Chung-Direct Link
http://www.dslrnewsshooter.com/2012...-featured-live-on-matt-and-dans-nab-geek-out/​
The Original DVXuser BlackMagic Camera Thread: http://www.dvxuser.com/V6/showthrea...mera-Technology-Announcements-amp-Latest-Info
I am EXCITED beyond words about this! OMG! This simple seems too good to be true for the price range! If this is true I can't see any other camera ending up in my hands this year but this one! Thank you Black Magic for LISTENING and giving a damn about filmmakers! :D
It is awesome, and BlackMagic thanks you for being excited about it too. This camera was a blindsided announcement- Literally almost no one knew this was coming. It is definitely going to change the price & performance for this segment of the market
Thank you Blackmagic for ending the madness. I knew Sony Panasonic and to a lessor extent Canon couldn't do this for fear of hurting their other lines. Looking at it now it's obvious that a company like Blackmagic who already have the codec end of things sorted would combine a large sensor to a recording device and change the game. I have already spoken to a distributor and placed my name on a list. This is fantastic.
For everyone complaining about the sensor only being s16, it's actually a good bit bigger than standard s16. It's pretty close to m4/3rds, so all you guys shooting on gh1's and gh2's should be familiar with how easy it is to get some nice DOF with decently fast lenses
Awesome that you got yourself on the list Ryaninoz. Contgratualtions..... BlackMagic thanks you for believing in their product enough to get in line to get it. The BlackMagic camera is a revolution all on it's own. No other camera like this has ever existed at this price/performance it's coming in at- $2,999.
These are amazing times......
[size=+0]BlackMagic Digital Camera Info Thread:[/size] http://www.bmcuser.com/showthread.p...mera-Technology-Announcements-amp-Latest-Info
I'm willing to trade a bit of DOF for 4-5 stops of dynamic range, especially at this price. I would love to see a head to head with an Alexa. $60k vs $3k. This is very exciting news!
I think the BlackMagic camera is going to do quite well in that test. This literally sets a whole new game in motion. What's also awesome, this camera is not some prototype of something to come maybe next year, however it was developed, and then announced. Red showed us what a driven independent thinking Man ( Jim Jannard ) and Company can do. BlackMagic is doing this to, and this is great. Two awesome companies, delivering awesome products. Exciting times!
The S16 sensor is excellent. The M4/3rds sensor has always been good. Different tools for different needs. Doesn't make one tool better than the other.
I have a request: Could someone make a cool sensor chart showing 2/3 to S16 to APSC to Super 35mm and then Full frame. I want to add this to the front page/first thread so people can see the crop factors. If anyone could do this, it would be very appreciated.
Guys shooting GH1/2 will also know that's it's gonna be hardly possible to do any wide shots with this Blackmagic camera. Equipped with only Canon/Nikon mounts, there is simply no glass. Why won't they add PL or at least m4/3 mounting options? That would make plenty of wide lenses readily available and one could always put EF/Nikon glass using the adapter. Having said that, it's not really that much of a problem for me - I don't get too wide, Tokina 11-16 will do the job for me, but there are many people whose shooting style is more towards wide end.
As long as it's got the EF mount, there will be lens mount adapters to get other mounts. Your wide limitations will not be any different than you got with s/16. As for the m4/3rd, seeing how the BlackMagic is getting press in its first day of announcement. The 3rd party guys might serve up a solution since since there will be money to be made.
You're right some lens formats can be adapted to EF (PL f.ex.), but I doubt s16 lenses will cover the sensor. This narrows the lens choice drastically. The m4/3 lenses would perfectly fit here, if there was a way to use them and there is none.
Sure third party guys might (and probably will) come up with some kind of workaround (lens mount replacement). I was referring to what (and why) Blackmagic equipped their camera with. It would just make much more sense to put m4/3 mount, which allows for mounting almost every lens (the only problem being Canon EF and its electronic aperture) including native m4/3 glass, which seems to be very useful in the context of sensor dimensions. Also, replacing the lens mount can result in warranty issues - we've seen this before.
