Okay, so since you don't have a picture that shows it work together, can I return the items in for a full refund if it does not work? The reason I asked is because the microArm has 1/4" 20 male screws on each end and the microMount has male ¼” 20 adapter with tightening ring. So, can you explain how to males with both 1/4" 20 thread can connect to each other?
I'm using the Noga with my 170 and the DP-1. It works very well - no complaints at all - rock solid, even hand held.
dmc
Thanks but if the camera is on a tripod then I won't need the external monitor. I need the arm mount so that it goes with wherever the camera is going. I'll be carrying the camera instead of putting it on a tripod.One thought; you can use an adaptor to mount the monitor on a small light stand and keep it next to your camera.
