Hello
I need to use some old VHS footage in a documentary , I would like to get the best quality out of this footage in order to do some color correction etc. I see the cheap converters around 50 dollar I see around are generally compressing to MPEG4. This documenatry is mainly shot with red and I am using FCP to edit. so, what would be the best codec or format I should get the VHS? I have seen a device that converts to H.264, cost 200 dollars, although I would not like to spend too much money in this VHS conversion.
I got a Mini DV camera with a minijack analog input, I though converting to MINI DV tape and then capture that from the camara with firewire in FCP. would be that enought or at least better than MPEG4 or H.264?
Thanks a lot
Thanks a lot
