I am a newbie to the HVX200 & FCP and i want to get the highest quality output i can. Our current workflow is as follows:
We have been shooting in 720/25P, transfer P2 contents onto hard drive and import into FCP (6.0.5) using log and transfer (Mac Pro 8 core). In FCP our Capture preset is DVCPRO HD 720p/25 and the Sequence preset is also DVCPRO HD 720p/25.
We typically Export the sequence using QuickTime Conversion:
Compression Type: H.264
Quality: High
Framerate: Current
Key Frames: Automatic
Encoding mode: multipass
I am not happy with the compressed end result. I know there must be better ways to achieve a higher quality image. Can anyone recommend settings/workflow improvements? Seems to me that we are compressing our image twice. When we transfer the P2 MXF files, they are converted into compressed MOV for editing. And then when exporting, FCP is using the mov files in the sequence and its again compressed. Am i missing something here? Shouldn't FCP be able to reference the original uncompressed MXF files when making the export?
Should we be using ProRes and if so, how? Also there seems to be an issue of dimensions of HD files. What dimensions should we be exporting to in order to get true HD?
Stupid questions i know but its all a learning curve for me right now. Any help appreciated.
CM
Quality: High
Framerate: Current
CM
