canada John
I waited and have just purchased a GH4 with a serial number well past the point where the “buzz” is said to be fixed. So hopefully all will be well.
Till now I've been accumulating information on the “fixes” suggested when a “buzz” was the problem. Most commonly it was said to set the GH4 at -12dB and the Zoom Line/Mic out at 0dB (Erik Neso).
I'm wondering how that has changed. What is the best set-up for a “non-buzzing” GH4?
The Zoom H5 has the ability to adjust its Line Out to Mic Out levels. It is set at 0dB and can go as far as -30 dB.
I also note that a Sescom cable sold to connect the Line Out of earlier models of the Zoom to camera mics like the GH4's has an attenuator of -25 dB.
Can I draw from this that with the “fixed” GH4 one should set the Lin/Mic Out at -25 dB?
If so what would one set the GH4 at?
Or is there still reason to send a stronger signal to the GH4 and set the GH4 to something like -12 dB?
(I will be recording directly to the Zoom and may have to use that but was hoping to get as good a recording to the camera at I could. Life would be less complicated it that audio was good.)
Thanks.
John
Thanks.
John
